So as you probably know I have had multiple threads about my bad h100i temps (50degrees idle and 85 under load) . Soooooooo I re situated the h100i and applied new paste and now I get 30 degrees on idle and at 100% load on Very High settings with IntelBurnTest I get 70 degrees max and it hovers around 50-60 on average. Would you guys say I can call it fixed?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/443967-h100i-temps/
stock temps? no
overclocked temps?  maybe
i dont even get 70c with my cooler at 4.7ghz 1.3v.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950198
stock temps?
yes but it's a haswell :P
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950201
my 4690k doesnt even reach 70c on prime 95 at 1.3v volts at 4.7ghz and my cooler is around as good as yours.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950209
stock temps? no
No wonder.. you have a 4690k I have a 4670k
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950211
looks fine
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950212
I would call that a fix
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950216
still haswell...... so youre telling me a stock 4670k vs a stock 4690k gets 20c more? no it doesnt my friend.
stock mine only hits 50c max  on prime95 which hits it big.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950220
4690K is a revisioned 4670K because it was known for getting hot under load
        Setup
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950225
look here and this is one at 4.6ghz
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950231
The haswell refreshes run WAY cooler fyi
There might be some other variable increasing his temps but the main thing would be that its a 4670k and not a 4690k
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950239
I don't see what you are getting at.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950242
maybe this will help you understand  better, i think it should still be lower, look at the max temps, hes only hitting 80c max at 4.8ghz and yours is touching 70c  at stock
http://www.overclock3d.net/reviews/cpu_mainboard/intel_4670k_i5_haswell_review_overclocking/2
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950252
I have seen him do this on other threads. People ask about a problem but he has to stomp on dead grass to make himself feel better.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950257
Plus with the haswell chips i've seen them either be overclocking gods with amazing temps or completely awful
He probs just got a bad chip
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950261
wtf you talking about? im trying to help or is this something you dont understand? wont help then, bye.
maybe, maybe not, maybe his cooler just isnt performing as it should be, im trying to help and hes not listening.
il let someone else help him, think most will agree a h100i should not be hitting 70c on a 4670k at stock.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950273
Not all chips are equal so remember that, I've seen people get unbelievable temps at high voltages with single 120mm air coolers so I wouldn't be surprised for bad temps at stock
        Setup
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950305
i know that, but at stock it should be irrelevant as they all run at the same voltage.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950309
My 2 cents, your temps are fine, idle and load.
Main Rig - i7 5930K // Corsair H100i // ASUS X99 Deluxe // Corsair Vengeance 16GB // Samsung 850 EVO SSD 250GB + 1TB // MSI RTX 2080 Gaming X Trio // Corsair Obsidian 550D // Corsair HX850 // Acer Predator 1440p // Windows 10 x64
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950318
there will be some differences, some will naturally respond to any voltage with heat and some will just deal_with_it_glasses_by_stewartisme_d5tu
id try verify it by testing two 4690ks on the same  cooler at stock but yeah i dont know anyone close with a 4690k.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950352
Well, this isn't quite the same but my 4460(haswell refresh) maxes out at 48c on the hottest core when stress testing. I have Be Quiet Pure Rock and run it at like 400-500 rpm.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950368
both have same tdp so will be  pretty close, mine actually hits around 45-48 on stock at 1.050v prime95.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950420
there will always be differences, plus there's the margin of error to consider too
yeah but not that much, i doubt you would see any more than a 3c difference at the same voltage.
https://linustechtips.com/topic/443967-h100i-temps/#findComment-5950430
