Suggested overclock speed?
Go to solution Solved by arronleeds,
... Oh. xD Whoops!
use 26.6 and if 4.3ghz isnt stable at 1.15v then bump  it up to 1.18v, try it again, then if its still not stable bump it up by 0.1, so 1.19v etc.
So I have an i5 4690k @3.5 (3.9 turbo).
The max I have recently gotten it to with my Hyper 212 EVO is 57C on two of the cores; avg of 55.5C under load.
Idle has gone as low as 29C.
What should I shoot for?
I don't know very much about OCing, aside from the fact that you want voltage to stay as low as possible.
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/443865-suggested-overclock-speed/
I went for 1.25V and 4.2GHz on my 4670k with a H100i. It's a safe place to start I'd say.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
do 4.3GHz OC
So change the multiplier or the clock speed?
And I would assume do it through the mobo bios?
let me ask my buddy who has the same cooler and cpu.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
i have 4690k and i run it @4.6 GHz with 1.50 V and under stresstesting to bring out max temps it never gets hotter than 77C (using antec kuhler 650)
WTF ARE YOU DOING!!!!!!! 1.5v!!!!!!!!!
thats a very very bad chip, mine can do 4.6ghz at 1.23v
you're gonna have a broken cpu very soon.
my friend has his at 4.5ghz, 1.19v and it hits around 70c with the same cooler, you may need more voltage depending on your chip, but aim for 4.4-4.5ghz.
I'll get back to this after class~ I like to test stability when I have large chunks of time available.
What should I look for to spot instability on OC?
you will get a bluescreen if its not stable.
sorry my mistake!
1.15V
was gonna say xD
thats a very nice oc is that for  a low voltage.
Will be doing the OC TOMORROW due to lack of time today.
do 4.3GHz OC
Got it to 4.19
Tried doing 4.4 in the bios, but the bios froze O_o
Did a cinebench stress test, got up to 76C. Haven't checked idle yet.
The thing that worries me is the voltage keeps going to 1.336... I didn't see an option to change voltage.
RESET TO DEFAULT FOR NOW!
I don't like the heat it was producing and I want to know its safe before I keep it there...
download intel xtu and il help you from there.
Have it up and running. Now what?
multiplier and go for something around 4.3. Just watch out for temps
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
what you want to do is go into "all controls" then you see the "core voltage" set this to around 1.15v and next to it make sure its "static", then you want to set your cores so that theyre all the same, start off at around 4.2ghz, if you get a bluescreen up the voltage, if you dont keep going up by 0.1Ghz, so 4.2,4.3 etc.
this is what mine looks like
I assume i have to restart it every time I change it?
no. all you do is change it and click apply.
no.
Ok... Then why didn't my speed go up after applying?
Do i have to change cache speed?
did you test it..... did you run a benchmark tool, did you click apply?
no all you do is change the core multiplier at the bottom.
show me what urs looks like.
Multiple programs say its running at 3.5 when I have it set for 4.2...
I did hit apply. and i'm running the intel benchmark.
