Im i the only one that has decent(awesome to me but horrid to others) routing inside the case but then outside of the case its a massive mess of wires and plugs and failed attempts of wire ties.
Listen if you care.
https://linustechtips.com/topic/44301-cable-routing/
Is this just a discussion about cable routing?
Case: Corsair C70 GunMetalBlack, CPU: Intel 3570k, Mobo: Asus p8z77-v lx, CPU Cooler: BeQuiet! Dark Rock Pro 2, RAM: 8GB Corsair Vengeance 1600Mhz lp, Video Card: Asus HD7950 DC2 Top V2, SSD: Samsung 840 pro, HDD: one Seagate 2TB Barracuda, PSU: BeQuiet! Dark Power pro 10 650w, Monitor: Dell UltraSharp u2412m, Keyboard: CoolerMaster QuickFire tk (Brown Switches), Mouse: Steelseries Sensei raw, Sennheiser HD 558
https://linustechtips.com/topic/44301-cable-routing/#findComment-580614
I use these: Velcro Reusable Self-Gripping Cable Ties (the actual branded one.. surprisingly good and low cost).  I use to use the monoprice ones, but they lose grip after a little while and are too thick.
I found them to be thin and very flexible, but strong.
My Rigs (past and present)
https://linustechtips.com/topic/44301-cable-routing/#findComment-581014
Nah,  I had to redo my cable managemnt because when I first did it I  was lazy, it wasent until I   got two 5.30 inch bays did I realize that the cable management  could cause majoar problem, took me about an hour to redo everything.
the front inside, those usb 3.0 headers are thick and difficult to manage
the  lovely work in the back, I still have problems closing that side panel but at least I wont damage anything,
Desktop:ryzen 5 3600 | MSI b45m bazooka | EVGA 650w Icoolermaster masterbox nr400 |16 gb ddr4  corsiar lpx| Gigabyte Aorus GTX 1070ti |500GB SSD+2TB SSHD, 2tb seagate barracuda [OS/games/mass storage] | HpZR240w 1440p led logitech g502 proteus spectrum| Coolermaster quick fire pro cherry mx  brown |
https://linustechtips.com/topic/44301-cable-routing/#findComment-581079
Okay, on the subject of awful exterior cable routing.. My router is downstairs from my computer so I have a 20m blue Ethernet cable going form my sitting room, around a book case and a radiator, up some stairs, round a corner and under the door into my room. :)
https://linustechtips.com/topic/44301-cable-routing/#findComment-581083
Yeah, inside the PC it's pretty clean, but behind my desk.. I bet two thirds of the cables back there aren't even connected to anything and I firmly believe that they have started to reproduce. halp pleez
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/44301-cable-routing/#findComment-583329
Unfortunately there are still plenty of case companies who dont use enough space behind the back panel to route cables correctly.Something that should be priority in my opinion.I have a large tower and still have difficuly zip-tying mine then being able to close the side without it bulging.
https://linustechtips.com/topic/44301-cable-routing/#findComment-608979
