I don't know what case to get and i have looked at the NZXT Phantom 410 which is weird to build in, so i've heard
So i want to get the NZXT H440 Black and red to go with my colour scheme and to eventually put red LED strips inside.
I need to know if everythingn will fit in the mid tower build with this set up: http://uk.pcpartpicker.com/p/N2hzcf
thank you
-Yorkie
https://linustechtips.com/topic/442664-what-case-first-build-ever/
You need a Z97 motherboard for that 4690k
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
No it won't. The H440 has no optical bay. Why do you need a DVD drive anyway?
Also you can't overclock on that board. But rather then getting a z97 board, I would recommend getting http://uk.pcpartpicker.com/part/intel-cpu-bx80646e31230v3 as it is an i7 without iGPU.
Either get 4460 with H97 combination or 4690K with Z97 combination.
I'd select G2/GS series PSU over NEX series PSU. Or Seasonic.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
i wans't planning on overclocking doe, does that still matter??
Then why the hell do you have a 4690k.
Get a 4460 then
And then go with H97 if you want to be safe. B85 may not come shipped with the BIOS update.
Get a better PSU anyone from seasonic or xfx or EVGA G2
Then get 4460 CPU with H97 board.
If you overclock, you'll get extra performance.
What about this?
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  (£138.51 @ Ebuyer)
Motherboard: ASRock Fatal1ty H97 Performance ATX LGA1150 Motherboard  (£79.99 @ Amazon UK)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  (£241.01 @ More Computers)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  (£76.00 @ Aria PC)
Power Supply: XFX TS 650W 80+ Gold Certified ATX Power Supply  (£57.94 @ CCL Computers)
Total: £666.14
Generated by PCPartPicker 2015-09-02 18:47 BST+0100
