      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/442311-fans-for-a-pc-help/#findComment-5928187
im in norway and i want some high cfm fans for a cheap price
Please link us to where you're shopping, list your specs, and where you plan to use the fans.
Moving thread to Air Cooling--the Troubleshooting section is for... troubleshooting.
https://linustechtips.com/topic/442311-fans-for-a-pc-help/#findComment-5928268
look around for some of those old dell optiplex towers. those 120mm DELTA brand fans can chop a finger off easy. Or look for some used server fans.
https://linustechtips.com/topic/442311-fans-for-a-pc-help/#findComment-5928296
Take a Delta-Fan http://www.newegg.com/Product/Product.aspx?Item=N82E16835706022 or http://www.sidewindercomputers.com/de12tfexhisp.html
they're about 4,5k RPM and should guarantee airflow - if you don't have to hear them
You are allowed to have animated avatars on LTT, but - try to have images like "userbars" in the signature - no chance...
Excels last cell is XFD1048576 and once was IV65536.
(if you want to have the most effective mousepad - use a colored matte floor tile)
https://linustechtips.com/topic/442311-fans-for-a-pc-help/#findComment-5929747
