B4 i render it looks like this
but after it looks like this
the black edges happens on both vector and png? and fixes or someting? did I do something wrong? Ive tried transparent backround or a solid white backround but neither fixes the problem
https://linustechtips.com/topic/442285-after-effectsvectorpng-image-help/
Could you share the project file or part of the project file with us?  I am not sure what you are trying to render, but perhaps we can help if we understood it better.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
just some solid colors moving across the screen then a logo. but the logo is a PNG and it turns out to have a black outline
So your logo is a PNG image file you imported into AE?
Are you sure it is a black line or just an illusion that makes it look like there is a line.  You have a solid color polygon on top of a white background.
black line is the final product. its there at the final render. I tried a vector and a PNG And they both are the same
Can you post a video of your rendered output?  I am trying to replicate your problem in AE using a PNG image and white background but I don't seem to have your issues.
im not home right now. and its going to be like 5 hours before I am so...
after pixel peeping with photoshop(zooming in till pixel by pixel is visible) it seems that there is a single line darker red before it goes brighter, might be the way AE handles the diffrence between coloured and white sections, not really sure though since I never saw it before.
May the light have your back and your ISO low.
That's what I think also.  The only way to be sure would be if the OP would share his project file, it doesn't have to be the complete file, with only the elements necessary for us to explore the error and see what is causing it.
