Hello guys,
I'm kinda a hardware newbie (well I'm learning since 3 or 4 weeks, better than nothing) so, I would need some help to choose the "best" case available for my following build (a friend and my poor knowledge helped me)  :
Case : ?
CPU : i7 6700k
GPU : Asus GTX 980TI Strix
Mobo : Asus Maximus VIII Hero
RAM : 2 x 8GO G.Skill RipJaws V 3000mhz CL15
CPU Cooler : Noctua NH-D15
HDD : Seagate Barracuda 2TO
SSD (games) : Samsung 850 PRO 512GO
SSD (OS) : Samsung 850 PRO 128GO
PSU : Corsair HX750i
Fans Case : ?
So, about the case :
- I don't want to use watercooling for the moment (I know the pros & cons, but I'll will try later with more knowledge and experience).
- Airflow/Noises > Skin (a good skin and a window would be bonuses).
- 50-500€, I can spend more depending on the quality of the case and necessity.
- I can buy case fans, that is not a problem.
First, I was thinking about a Thermaltake X9, but I think it would be too much without using watercooling. Then I was thinking about a case which supports a 90° motherboard orientation, like the Raven RV05, but I read that it is bad for the GPU coolers ( http://www.overclock.net/t/900251/gpu-coolers-that-actually-work-in-90-rotation-ft02-rv02 ).
So I'm a bit lost haha. Please let me know if you have any opinion, suggestion or advice.
Thanks a lot and have a nice day.
PS : I'm not a native english speaker so excuse me if you find some mistakes in my topic.
https://linustechtips.com/topic/442089-some-help-to-choose-a-case/
Hello guys,
Case : ?
CPU : i7 6700k
Fans Case : ?
How about the define s from fractal design. Great for watercooling and aircooling plus a big window to show off your rig.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
Air 540 :D
750D
Oh snap. How am I supposed to choose haha.
What about the Fractal Design Define R5 ? Is he better than the Define S ?
Thanks.
Thanks.
They are practically the same case. The r5 has has hard drive cages, and 5.25 inch bays along with a smaller window and less water cooling options.
