So I am going to buy Arctic silver 5 paste for my CPU but people have been telling me opposite things reguarding application. Do I apply it to the h100i (like it comes preinstalled) or do I apply it to the cpu itself. Approximately how much do you think will get the job done?.. the tube is 3.5g. Also should I spread the thermal paste with a credit card because people have ran into issues using the blob or cross method. Thanks a lot and sorry for any misspellings I'm on my phone.
PS: Don't tell me to use the h100i thermal paste that it comes with because I have used it for over a year and going to replace it now.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/
Grain of rice sized blob on the CPU. Don't spread it.
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/#findComment-5921342
You apply it to then CPU, and an uncooked grain of rice size pea should be fine for thermal paste, no need to spread or do the cross method.
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/#findComment-5921348
But if it is the size of rice and gets pressed out between the h100i and cpu, won't the edges of the cpu be missed?
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/#findComment-5921359
it doesn't matter, the only thing that is near the sides of the CPU is the memory controller, the cores are in the middle part the rest is PCB
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/#findComment-5921365
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/#findComment-5921398
major coverage would be like the picture above, enough to cover the die. the
minor coverage would be the rest of the IHS of the CPU. as long as the major
portion is covered the minor is "bonus".
the pea/grain method applies for both coverage. the tension of the cold plate
will distribute the paste.
AS5 will need a "cure/bake-in" to show best performance. most do not want
to wait and use the noctua nt-h1 or artic mx-4 (which require no cure-time).
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/#findComment-5921412
How do I do the burn in?
https://linustechtips.com/topic/441791-thermal-paste-and-h100i/#findComment-5929896
