I'm in college algebra, a dual credit class at my high school. We are reviewing stuff from Algebra II and I cannot for the life of my figure some of this stuff out, it's just not coming back to me. Here is one of the problems I am stuck on:
(32x^10y^5)^(3/5)
That is, 32 times x to the power of 10 times y to the power of five, all to the power of 3/5. I am supposed to simplify the problem but I'm just not sure what I'm supposed to start with. Can someone guide me through this? Thanks!
Also stuff like (x+y)^2 - 25, I don't know why but I just can't get any of these problems started, but once I get them started usually it's really easy to finish them.
https://linustechtips.com/topic/441689-can-someone-help-me/
8x^6y^5
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
https://linustechtips.com/topic/441689-can-someone-help-me/#findComment-5920098
Well I asked for help not just an answer. Could you please explain how you got that?
n/5 is the fifth root, 3/n is just cubed. Root it first AFAIK, haven't really looked at it too hard.
https://linustechtips.com/topic/441689-can-someone-help-me/#findComment-5920113
(32x^10y^5)^(3/5)
Distribute the 3/5 power in the parenthesis.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/441689-can-someone-help-me/#findComment-5920115
Okay, is this right?
After distributing the fifth root into the parentheses I get this:
(2x^2y)^3
Then distribute the cube into the parentheses and get this:
8x^6y^3
Is that right?
@werto165
Yes. Lol im 14 and i helped a college student
https://linustechtips.com/topic/441689-can-someone-help-me/#findComment-5920157
What happens if the the equation has a negative root to it? Like it's -2/3 instead of 2/3, but there are no fractions for it to flip. Would it be 1 over whatever is in the parentheses?
it flips everything under a fraction
so 1^-1 would be 1/1^1
2^-3 would be 1/2^3
https://linustechtips.com/topic/441689-can-someone-help-me/#findComment-5920171
Thanks so much, makes so much more sense now.
I thought the answer would be 8x^6y
as x^a * x^b = x^a+b I think
https://linustechtips.com/topic/441689-can-someone-help-me/#findComment-5920214
