first build and first time dealing with OS install
Solved by Atmos,
Download an ISO for the windows version key you buy, then using the dvd/usb creation tool from microsoft turn a cd/usb into a boot device using the iso you downloaded.
You can find a download link to windows 7 here, if that's the key you bought.
Then once the computer is built, put in the disc/usb and go through the install, when prompted choose your version (always 64bit, and what ever edition) and then you will be prompted to insert your key that you bought from g2a/softwareswap.
