Here it is! The final build plan. Planning for at least 3 years out of this machine.
CPU: Intel i7 4790k
Motherboard: MSI Gaming 5
RAM: Corsair Vengeance Pro DDR3 2400 16GB
Video Card: MSI GTX 980 ti
SSD: Samsung EVO 850 250GB
HD: 2x 1TB WD Blue
Liquid Cooler: Corsair H100i GTX
Display: ASUS PB278Q 27"
PSU: EVGA SuperNOVA 750 G2 Full-M 80+ Gold 750W
Case: Corsair 750D
https://linustechtips.com/topic/441517-final-build-plan-thoughts/
why,it wiill run cooler and be smaller
OT:
skylake?
just seen it said GTX. not sure if it's better than the nh d15 sorry, I was going off of h105 benchmarks.
Though the d15 does seem to be generally better.
CPU: I7 4790k  CPU Cooler: NH-D15 GPUMSI 970 4gb   Motherboard: z97 Gaming 5 PSU: Corsair hx850   Ram: Corsair Vengeance 8 gb  SSD: Samsung 850 Evo  Case: Air 540
CPU: Intel i7 4790k
HD: 2x 1TB WD Blue
Case: Corsair 750D
whats this gonna be used for?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
I'll use this for photo editing and 1440p gaming.
Fine!
Looks good!
But you don't need the 2400MHz on that RAM.
Just get a 1600MHz. It's good.
Also that case seems to be expensive. Get NZXT S340, if you like it.
I'd go for NZXT Kraken X61.
Why go for 2 x 1TB HDDs?
Get WD Black 2TB. They are good! Save one SATA Port. :P
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
