Recently, the audio on my front panel audio jack is going a little haywire. It randomly reduces the volume (without physically lower the volume bar), as well as reducing the audio fidelity, cutting out almost all the lower end and making things sound really tinny and hollow. Trying to increase the volume does not have any effect. After a while like this, it'll go back to normal, but it's getting more and more frequent. It's extremely frustrating when I'm trying to listen to music or talk to people on Skype. Strangely, it only seems to impact the front panel audio, as my speakers seem to be fine. I've tried updating drivers and fiddling with other audio options (like balance), all to no avail. I have no idea what's wrong, and would really like a fix. My build is in my signature, in case knowing the parts helps anyone figure out a diagnosis.
CPU - Intel i7-4790k | CPU Cooler - Cooler Master Hyper 212 EVO | Motherboard - Gigabyte GA-Z97-HD3 (Rev 2.0) | RAM - G.Skill Ripjaws X 16GB (2x8) DDR3-1866 | Storage - Samsung 850 EVO 500GB SSD | Graphics Card - EVGA GeForce GTX 980ti SC | Case - Fractal Design Define R5 w/Window (Black) | PSU - EVGA 750W B2 | Display - Acer K272HUL | Keyboard - E-Element RGB | Mouse - Logitech g502 | Sound - Klipsch ProMedia 2.1/Fostex TH-x00/Sennheiser HD595
https://linustechtips.com/topic/440202-weird-audio-issue/
I'm almost for certain it is the wire itself.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/440202-weird-audio-issue/#findComment-5901143
I thought it could have been that, so I double checked that the wire was attached properly. Maybe it could be the wire itself, but I'm not sure if I can really check that.
https://linustechtips.com/topic/440202-weird-audio-issue/#findComment-5901215
Yea, I'm almost for certain it is the wire.  Its exactly how a bad signal wire works.
https://linustechtips.com/topic/440202-weird-audio-issue/#findComment-5901233
More often than not, its the cable. I've had 3 interconnects for my headphone die on me. Everytime I think its my iphone audio jack I buy a new cable and its the goddamn cable/earpiece.
Try the speaker on your phone or something, that will narrow your options down.
•  i7 4770k @4.5ghz 1.248v • Noctua NHD14  •  ASUS MAXIMUS VI Hero •  Asus STIRIX 980 Ti •
•  Corsair Vengeance Pro 16Gb  •  Samsung 840 250gb + Samsung 1TB 7200RPM •  BenQ XL2430T 144Hz  •
•  Fractal Design R4  •  CoolerMaster GX650 80+ •  Razer Deathadder Chroma  •  Filco Ninja 2 Red  •  HD600/HE-4/ Fiio E17  •
https://linustechtips.com/topic/440202-weird-audio-issue/#findComment-5901281
I've tried different pairs of headphones on the jack. It's definitely not my headphones.
https://linustechtips.com/topic/440202-weird-audio-issue/#findComment-5901426
What can I do to fix this? Do you know if I can buy replacement wiring?
https://linustechtips.com/topic/440202-weird-audio-issue/#findComment-5901429
Most likely a cold solder on your wire. Sadly, not an easy replacement especially if its speakers with non detachable cables. Unless you find someone online to replace the cables it might be RIP for your speakers.
https://linustechtips.com/topic/440202-weird-audio-issue/#findComment-5903529
