I'm having some problems.
Go to solution Solved by Whaler_99,
First off, I noticed you do not have the client-type advanced Flag set on the GPU slot - check the Folding FAQ for that. Will make you availble to get Core17 projects,
Also, some WU's yeild a lot fewer PPD then others. Just because you been getting 10K for the past few weeks, doesn't mean with project X you may only get 4k. Luck of the draw my friend. But definately get that flag set.
As for the laptop, what specs? I know mine was amazingly slow. :) And I have a corei7 mobile... Ended up not being worth it as the unit got so bloody hot.
I've noticed that recently I've had a very low PPD and I have no idea what is causing it. (Screenshots below)
While you're here my laptop says that it's folding, however when I go into the control, there is no ETA or PPD and is stuck at 0%
Any help would be greatly appreciated.
Thanks,
Sam
https://linustechtips.com/topic/44015-im-having-some-problems/
Maybe you should reinstall windows.
"You know I was taught that if you don't have anything nice to say, don't say anything at all. You feeling me cocksucker?"
"Ethernet is internet juice. You have to press the internet really hard and you will get it."
"My quantum milk machine brings every boy to all the yards." non futuis et sursum
PC Specs! | I7-950 | 24GB RAM | 10TB Storage | GTX 970 Strix and a 560TI DCUII for Physx | 120GB 840 + 250GB 850 EVO | Asus xonar DGX
Please take a moment to look over the forum CoC here.
https://linustechtips.com/topic/44015-im-having-some-problems/#findComment-576410
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/44015-im-having-some-problems/#findComment-576470
Thanks for the help, it just doubled my PPD. As for the laptop it has an Intel i5 2450m. The only reason I'm doing it on my laptop is because it isn't actually doing anything so I thought I might as well put it do good use.
Edit: Turns out my laptop was actually folding, just extremely slowly. 3 days for one WU to be precise.
https://linustechtips.com/topic/44015-im-having-some-problems/#findComment-576530
Ya, laptop mobile chips are pretty weak. If it is just sitting there and it can handle the heat, fold away! :D
https://linustechtips.com/topic/44015-im-having-some-problems/#findComment-576560
If you are folding on your main rig, make sure you are folding on 3 cores. amd gpus need some cpu power to run at full potential
AAAAAAAAAGGGGGGGHHHHH!!!!
https://linustechtips.com/topic/44015-im-having-some-problems/#findComment-576732
