150$ Max Speaker Setup
Ok I currently have a Logitech z623, and I love it. Dunno if it's because I never listened to anything better or because it's really good, but what I want is something similar or better. I can't get another z623 because it's really expensive right now, and I can't order it online (shipping charges will suck me dry because of its weight).
So I am thinking a pair of bookshelf speakers + a Lepai amp:
Amp:
http://www.amazon.com/dp/B0049P6OTI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=NWS1TLUNH54O&coliid=I862NNTG6EQ6&psc=1
Candidate Speakers:
http://www.amazon.com/dp/B000OG88KY/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=NWS1TLUNH54O&coliid=I3I0431IRK3NB4
http://www.amazon.com/dp/B000MCGF1O/ref=psdc_172563_t3_B000OG88KY
http://www.amazon.com/dp/B00N8265I8/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=NWS1TLUNH54O&coliid=I2LLSS1YFG2FBC
___
The small size is not necessary but a good plus, hence the Pyle and Micca pairs.
What other setups do you recommend? I don't think I can get a sub woofer, but is it necessary in order to get a similar experience as the Logitech z623?
Thanks. ^^
https://linustechtips.com/topic/440137-150-max-speaker-setup/
Amp:
Candidate Speakers:
___
Thanks. ^^
The z623 is legitimatly a good speaker setup, given its price point.  Give me a little bit.
AMP: http://www.amazon.com/dp/B003NVN1PY/ref=s9_acsd_bw_wf_s_LiveSoun_cdl_4?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=merchandised-search-7&pf_rd_r=1SCWZPVAGP1DGRG6ACD8&pf_rd_t=101&pf_rd_p=e751b972-6f7b-4341-af28-65eb09cf8003/44852d8d-8e78-4be3-961b-220effd860d2&pf_rd_i=405757011
Speaker: http://www.amazon.com/VM-Audio-VAS36P-Passive-Speakers/dp/B00MBJQTBC/ref=sr_1_12?s=musical-instruments&ie=UTF8&qid=1440883835&sr=1-12&pebp=1440883878568&perid=0X5ZBF0FGPM3K6PH0SHH
All In One: http://www.amazon.com/dp/B00X741TB0/ref=twister_B010EEXY36?_encoding=UTF8&psc=1
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/440137-150-max-speaker-setup/#findComment-5900383
Amp:
Candidate Speakers:
___
Thanks. ^^
I personally wouldn't get that amp. Its wont be that great.
My suggestion (and what i did) was check craigslist and look for a Home Theater Receiver used...(people usually sell them pretty cheap), and then whatever money you have left over buy speakers...Monoprice has some really good bookshelf speakers.
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/440137-150-max-speaker-setup/#findComment-5900429
That's what I did
Used speakers, used receiver
https://linustechtips.com/topic/440137-150-max-speaker-setup/#findComment-5900447
That's what I did
I tried, but I couldn't find anything on the local craigslist :/
Mackie CR4 or Micca PB42X I think will be good options for your need
I can't get the amp with the Mackie...is it not necessary?
So the PB42X is better than the Sony? 100 watts and stuff :P (no Idea if more is always better)
https://linustechtips.com/topic/440137-150-max-speaker-setup/#findComment-5900499
That's what I did
Yee! And the receiver i got had an optical-in so i didn't have to use a standard audio connectors which is nice. To the OP, Definitly try to get a used Home Theater Receiver... You'll thank me later!
https://linustechtips.com/topic/440137-150-max-speaker-setup/#findComment-5900500
I tried :'(
And if they weren't too heavy, I would have even ordered a new one long ago.
https://linustechtips.com/topic/440137-150-max-speaker-setup/#findComment-5900555
Ok I actually found a way to get a receiver, but I dunno how to choose one, and I still don't know which speakers to go with whatever receiver I get. I plan to connect both my PC and PS4 to the receiver. I found many with 4k capability, and I don't care for 4k, which will save me some money. I am currently relying on reviews.
https://linustechtips.com/topic/440137-150-max-speaker-setup/#findComment-5900755
