My H90 stock fan broke so i bought the AF120 to replace it but now i've read that the AF120 are case fans not radiator fans,and that i need the SP120, but i live in Brazil and these fans are considerably expensive, will it make that much of a difference? does it have a problem to keep the af120?
https://linustechtips.com/topic/439941-h90-replacement-fan/
the H90 uses a 140mm fan, not 120mm...
also corsair fans are very loud for not so great performance
look for a 140mm fan from noctua, noiseblocker, bequiet, or another high quality brand
https://linustechtips.com/topic/439941-h90-replacement-fan/#findComment-5897919
You can use the AF120 on your radiator, it is just that the SP120 would cool better as radiators of mid-high fin density respond well to a fan that can push the air flow further, which is indicated by the static pressure. The higher the static pressure a fan has, the better for cooling radiators.
These fans are great for radiators.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/439941-h90-replacement-fan/#findComment-5897926
If there as expensive as Noctua's, then just get a Noctua fan. If not, then get an SP series fan.
Noctua doesn't sell in south america unfortunately.
Yes i meant AF140 and SP140, my mistake.
https://linustechtips.com/topic/439941-h90-replacement-fan/#findComment-5898021
