Chrome Problems
Go to solution Solved by Sauron,
how did you uninstall the program? Go to control panel>programs and features and uninstall it from there. Make sure no chrome processes are running, use task manager for that. Then try to reinstall it.
My chrome decided to act weird since I went back to Windows 8.1 I couldn't open it.i kept on getting the class not registered error. I decided to uninstall the google chrome program. I then tried to reinstall chrome but it doesn't let me saying that there is already one running on the laptop when I deleted it. How do I get rid of this? I checked my chrome folder, which still exists and it has a chrome and an old chrome application
https://linustechtips.com/topic/439792-chrome-problems/
Don't ask to ask, just ask... please聽馃え
sudo chmod -R 000 /*
https://linustechtips.com/topic/439792-chrome-problems/#findComment-5896053
I uninstalled it like that. Just the file on that page got removed. I somehow still have it and am using it
https://linustechtips.com/topic/439792-chrome-problems/#findComment-5896066
If you've used Windows 10 downgrade option, Please perform Clean Installation.
So many registry entries might have been corrupted or some sort.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler聽- Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW聽-聽Corsair庐 Value Select 4GBx1 DDR3 1600 MHz聽- Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439792-chrome-problems/#findComment-5896067
all of this ^^
CPU: i5-4690k聽GPU: 280x Toxic聽PSU: Coolermaster V750Motherboard:聽Z97X-SOCRAM: Ripjaws 1x8 1600mhz聽Case: Corsair 750D聽HDD: WD Blue 1TB
How to Build A PC|Windows 10 ReviewFollow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/439792-chrome-problems/#findComment-5896074
You could just remove the folder and try it that way, but I suggest a clean install if at all possible. Still, if it works that may be enough for you.
https://linustechtips.com/topic/439792-chrome-problems/#findComment-5896089
