Going to buy some coolant for my loop.
Im new to this and want to know, can i just run only demineralized water, or what should i run?
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/
Yes you can run distilized water. You can also run specifical coolant for PC, or car coolant i you have any. (the green stuff)
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
https://linustechtips.com/topic/439245-coolant/#findComment-5889014
I don't know about demineralized... but distilled water, yes.. or maybe they're the same thing and I'm stupid
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/439245-coolant/#findComment-5889015
Normal distilled water is fine.
If you are looking to spend some money here
Buy EK Ekoolant or PrimoChill ICE
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439245-coolant/#findComment-5889037
Im not the master man in english but maybe they are :-)
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5889237
You can use distilled water if you want. It's pretty cheap. However, I would advise just going for a clear, premixed coolant instead. That way you don't have to worry about putting in any anti-algae additives.
How long can i without worried run on the same coolant?
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5889243
Distilled water plus kill coil
So, not just distilled?
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5889244
I'd advise changing it out once a year, or if it starts to discolour.
You'll want additives or a kill coil with distilled water. Algae can build up in the loop without them.
https://linustechtips.com/topic/439245-coolant/#findComment-5889258
Okay, so, im gonna run all black tubing, so ill just stick with 1 year between each coolant change.
About that kill coil, can i buy a little bottle and mix it myself?
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5889268
A kill coil is a little silver coil that you put in the loop, not something you mix. I'm assuming your reservoir is clear, so you should be able to tell when the fluid is discolouring anyway.
If you get the anti algae additives, you just put a few drops into the loop, following the instructions on the bottle.
https://linustechtips.com/topic/439245-coolant/#findComment-5889281
Okay, I see. How does That kill coil get into the loop?
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5889363
you just put it in res, through fill port
https://linustechtips.com/topic/439245-coolant/#findComment-5889377
You can put it in the reservoir before you fill the loop, or you can put it in one of the tubes so that it's not visible.
Im gonna hide the res and pump in the rear compartment of my case as theres no space when my 40mm thicker radiator is om there too :-)
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5889431
Also, im looking for a 2 way fitting to go from my rad where the one way is going to be a drain port, is there a drain port with a 2way fitting?
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5889649
A T-fitting works well, just to add to the distilled water and kill coil if your using nickel plated waterblocks go with a biocide instead since silver and nickel plating can cause some problem.
http://www.performance-pcs.com/bitspower-rotary-fitting-t-180-degree-water-cooling-accessory-black-matte-finish.html
https://linustechtips.com/topic/439245-coolant/#findComment-5891009
My cpu Block is an ek supremacy evo Copper. Just add a silver coil in res?
So, that t-fitting will work well? What about a drain valve, what should i choose there? :-)
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5891185
Silver with copper is not a problem having the coil in the res or tubing as others have suggested is good, for the valve itself something like this is ideal, with a short length of tube when draining and a cap in place when not in use.
http://www.performance-pcs.com/bitspower-bp-mvv-mbk-mini-valve-matt-black.html
https://linustechtips.com/topic/439245-coolant/#findComment-5891237
Okay, but that valve, thats inner thread in both ends, how do I fit that on my radiator, can I use a 13/10 fitting and just screw on the valve or how does it work?
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5891296
Well it depends on your setup if your using an extra port on a radiator as your lowest point as a drain you can use a male to male fitting to connect the two G1/4 ends together.
http://www.performance-pcs.com/bitspower-mini-dual-g1-4-high-flow-fitting-black-matte-finish.html
https://linustechtips.com/topic/439245-coolant/#findComment-5891323
Im running my front 360 rad with fittings pointen down, so yes, the lowest spot :-)
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5891358
Also, can I paint my silver fittings black or is that not recommended?
Built  Not Bought
https://linustechtips.com/topic/439245-coolant/#findComment-5895203
