Hello Linustechtips,
Yesterday I took my desktop apart to clean out dust and what have you... Didn't touch any components such as RAM, GPU, or the CPU. But for some reason when I reassembled it, turn it on. Nothing happens.
The screen stays black, I tried swapping in a new power supply, it still stays back. Tried an old GPU I had, and still nothing. The speaker in the desktop doesn't say a word either.
The LED on the Mobo stays solid green,
Done everything mentioned in the thread How to respond to a no POST or no power up situation
Thanks for your time in advance ^.^
---Spec---
CPU               - Intel® Core™2 Duo Processor E7200
CPU Cooler     - Hyper Evo 212
RAM               - 2x2GB G.Skill DDR2 @ 800MHZ
GPU               - NVIDIA GeForce GTX 650 Ti
MOBO             - P5Q PRO
https://linustechtips.com/topic/43896-problem-booting-up/
It sounds stupid, but did you plug everything back in properly? 24-pin, CPU power, PCI-e power if you need it, GPU power
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574622
How did you clean it? If it have been disconnected from the power outlet try and clear the CMOS
I used a vacuum cleaner on the lowest setting, made sure it didn't touch anything - clearing the CMOS and BIOS right now
-Cleared the CMOS and nothing new.
Yes, went about to double check it after I found out it wouldn't boot
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574632
For future reference.
Don't use a vacuume cleaner to clean a the inside of a computer. Those things produces static like crazy
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574646
Try onboard video, I know you ruled out GPU but the slots may be dead or something
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574649
Posted the specs in the first post now. - Don't support onboard if I remeber corrently
Sorry for the long reply, I got caught up in editing a video, you tried everything on that list? That's quite extensive. Given that your computer still won't post I'm going to have to guess you damaged something while cleaning, the static build up may have shorted something. Also, given how extensive that list is I'm going to suggest that it is your motherboard that is damaged... I suggest trying to flash your BIOS first before drawing any conclusions
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574709
Done everything mentioned below The machine does power up, but my screen remains black (no POST).
Flashed the Bios and Cmos before, still no post D:
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574716
If you don't get anything then it's hard to determine what thing is causing the problem. I'm more and more convinced it's a hardware problem. Out of curiosity though, does everything spin up such as fans and optical drives/hard drives and it just doesn't display anything?
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574725
Yes, everything spins, gpu fan, cpu fan and all case fans.
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574750
That's interesting. I have a similar problem with a computer I decided to build from scrap parts, everything spins up. I think it's the CMOS battery itself that is causing the problem. On my system at least, maybe it's the cause for the problem on your system too
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574756
Alright so, I've done what is labled here
http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&p=1&m=P5Q%20PRO&s=22&hashedid=qH6ZSEJ8EPY6HoNU&os=&no=1723
Which is basicly how to clear the cmos on the mobo.
But I've put the cap over the 2 pins to clear the cmos, Putting it back in 1-2 turns it on, but still don't post
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574775
You can clear the CMOS all you like, but if the battery is dead then it won't matter...
https://linustechtips.com/topic/43896-problem-booting-up/#findComment-574787
