http://pcpartpicker.com/p/1pB0e
I live in sweden and there is a 7990 for the price of a 780 plus you get 8 games so i decided to get.
i was wondering about the parts i chose if it is something i should change. The 840 series SSD is representing the EVO SSD since it avalible in sweden.
There is no CPU cooler because im making a custom loop with metal piping
https://linustechtips.com/topic/43869-need-help-with-7990/
Higher PSU for Headroom. Overall the build looks great!
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574202
geez....thats about how much i paid for my build...
but ya i would upgrade the PSU. maybe the AX760i :D
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574215
If i were you, I might up the PSU wattage a bit, maybe to 700W or 750W.
Estimated wattage for the system is 628W, and the PSU is 660W.
Doesn't leave enough breathing room in my opinion.
I might be wrong though.
You might want a higher watt psu. I don't arc midi is big enough for 7990 length unless you remove the drive cage.
I said it first! Haha! :P
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574221
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574232
Why not matx?
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574245
By one minute! I was ninja'ed!
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574248
Nah ax760 is what im getting since here it is the same price as the 660 seasonic one
still a great power supply! :D
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574250
Nah im more an ATX guy plus more stpace for my loop :)
+1
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574281
As already said, bigger PSU, but no need to go platinum.
Arc is great for airflow, if you are looking for silent go Define R4 instead
7990 is great, but in my opinion to expensive. I would choose a cheaper one and get 2 ssd in raid0,16 GB ram and a better motherboard instead
Lycka till
A computer once beat me at chess, but it was no match for me at kick boxing
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574307
Lycka till
Same price as 780 is not to expensive and i do not need 16gb of ram plus it is a good mobo and the only decent one who works with my color scheme
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574315
Where do you get a 7990 for the same prize as the 780?
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574382
Everywhere, AMD cutted down the price of this * card to the price of a 780.
I'm seeing 1000€ in Poland sadly. :(
Maybe in few months.
On the other hand we have broadly available Phenom II x4 965 and x6 1045t at respectively 350 and 400PLN which translates to 110$ and 130$. :P
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574534
This might help you then : http://www.alternate.pl/html/search.html?query=7990&x=-337&y=-150
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574539
Dayum just updated to 3100PLN. Still well over 700€ (closer to 800€) but what the heck.
I'd still preffer Nvidia GPUs even though 2x 770 4GB is 3500PLN while 2x 760 4GB is 2400PLN... and 780 = 2500PLN while 2x7970 (non GHz) = 1300PLN.
https://linustechtips.com/topic/43869-need-help-with-7990/#findComment-574933
