Two fans one Splitter
AgahPT
Hi,
I've begun upgrading my case with some new fans and i bought some PWM Y Splitters, I know that i can only monitor one of the fans connected to the Y.
My question is: Does it make sense to buy NON PWN fans (about 40% cheaper) to attach to the non monitored Y connection since the monitoring wouldn't work anyway.
The final configuration would look like:
         +------------+                     |            |                     |  MB HEADER |                     |            |                     +------------+                            |                         +-------------------+              |                   |       +------------+     +-------------+ |            |     |             | |   PWM FAN  |     |   NON PWM   | |            |     |             | +------------+     +-------------+ 
Yes,But speed control won't be possible unless,your mobo supports voltage control
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
if it get's to loud you can do this.
                                                           |------------------------------------------------------------------------------------------PWM FAN
Motherboard connector---------------|
                                                           |-----------Voltage stepdown (low noise adapter)------------------ 3pin fan
I'll be using my MB (ASUS Z87-PLUS) headers and AFIK the only "real PWM" headers are the CPU and CPU_OPT headers all the others just shoot 5V over the 4th pin.
Can anyone confirm this?
4pin is probably all PWM because you can plug a 3pin fan in a 4pin connector and vice versa. I don't think that 5V is the voltage it outputs. most fans start above 6V and the nominal voltage is 12V
I better stick a multimeter there to check that out for real :)
