Hey Guys,
I'm going to be doing a new build in the next few weeks and I'm not sure on what CPU to purchase. First let me give you a bit of background what it will be used for. It will mainly be used for gaming however i do like to stream and edit videos from time to time, hopefully more with the new rig, im also a graphic and 3d artist so i do a lot of rendering and in engine stuff. At the moment I'm looking at 2 cpus, First the i7 6700k and second the i7 5930k (for the extra 2 cores). Now my question is knowing what i will be using it for are the extra two cores worth it as i would like to future proof the build for as long as possible, I would also like to make use of DDR4 so dont really want to go for something like a 4790k.
(forgot to add on will the difference in clock speeds make a noticable difference)
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/
5820k would be better.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873038
I think you have narrowed them down to the correct options. If it were me it go X99
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873044
Hey Guys,
I'd go for the 5930k if I was u (or just if I had the money).
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873046
Go with the 5820K, the 5930K is unnecessarily overpriced.
It has more PCIe lanes. Depending on use, the customer either chose the wrong CPU or "he just doesn't knwo what he pays for".
It is not overpriced. You get what you pay for. Period.
3.Use
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873074
Dont buy i7 on the mainstream.. Choice is i5-6600K, i5 4690K or i7-5820K. X99 really doesnt have that much of a price premium anymore. I have the 5930K - mostly because I managed to pick one up for only £80 more than a 5820K, and I actually use PCI-E SSDs so its handy to have extra lanes.
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873108
The i7-5820K gives you an extra two cores over the 6700K as well but doesn't cost as much as the 5930K. Can be overclocked to beyond 4GHz easily with a decent cooler.
Intel i5-4690K @ 3.8GHz || Gigabyte Z97X-SLI || 8GB G.Skill Ripjaws X 1600MHz || Asus GTX 760 2GB @ 1150 / 6400 || 128GB A-Data SX900 + 1TB Toshiba 7200RPM || Corsair RM650 || Fractal 3500W
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873132
The 5820K has 28 PCIe lanes. That is enough of 2X SLI (8X/8X), as well as a bunch of add in cards/PCIe SSDs. Anyone doing over 2X SLI is stupid anyway, so 5820K is enough.
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873143
With the right reasonable motherboards (ironically smattered all around the price ranges with the sli plus being the cheapest to have it) 3 way sli is easily possible as well.
8x/8x/8x and a 3x4 m.2 ssd.
Literally no reason whatsoever to go 5930k when that same money could be spent instead on a super insane mobo that allows 4 way with a 5820k anyways. (Plx for the win).
@op
If you love near a micro center the 5820k will actually be cheaper and as such should definately be your choice.
If not, well, I'd still personally recommend x99 as it isn't a large premium but it does require overclocking and massively slower boot times, so if that sort of thing bothers you go z170.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873592
i have a 5820k... its op lol no fps drops or anything in games like csgo when streaming, my old i5 3570k lagged when i streamed so theres a great comparison
i7 5820K @ 4.4GHz | Evga GTX 980ti Superclocked | MSI X99 Sli Plus | 16GB Crucial Ballistix DDR4 | EVGA 850W Gold+ | 2TB HDD and 250GB SSD
NZXT Phantom 530 | Corsair H100i GTX |
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5873835
 how much slower boot times less than 30 secs? or more?
Mine takes ~1minute to desktop; but thats due to it still being on diagnostic boot and a LOT of drives. Its also a rampage which tend to take a little longer to boot. My Pentium G3220 (overclocked) + H81 mobo actually boot faster lol.
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5874106
I didn't express myself correctly I think. I never said you were wrong. I just wanted to correct you on the fact that the 5930 is priced higher without any point.
Your right with the fact that he is probably better of with a 5820. I just thought of these 2 since he mention only these. That was amid take on my side.
3.Use
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5875025
1 min on an SSD or HDD?? Never heard of that. I think I learned something new about x99 today.
3.Use
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5875042
When I turn on all the fast boot options available my average boot time is like 27-34 seconds with an ssd.
Honestly though, it is massively slower when you consider z97 with an I5/I7 takes only 2-5 seconds to boot with a ssd.
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5875461
SSD; But its still in diagnostic mode and there are a shedload of HDDs connected - And I didnt time it.
Always found that rampage boards tend to boot a little slower.
Ill try and time it for ya later..
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5877900
Nah you don't have to. I was just a little well surprised since my shitty old HDD based laptop takes about as long( 1drive only though :P). Guess that's just the way it works.
3.Use
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5878658
Sry for doing double post. How can I remove? Mod?
3.Use
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5878662
May just be my setups but I have always found enthusiast class hardware takes an order of magnitude longer to boot than mainstream (for example, P35, X58, X99 Chipsetts) vs G41, H61, H81 and even Z97.
Also number of dimms installed increased boot time in my experience
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5878756
My Z77 and Z97 ssds both boot in like 12 secs, I guess you had some shitty luck lol
Ryzen Ram Guide
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5881318
I am sure a lot is down to HDD and other settings - On the enthusiast grade stuff (X58/X99) I tend to have 8 disks minimum (in some kinda of raid array, usually raid 1 or raid 10) . Compared to at most on the normal stuff - And ye my H81 Boots Win10 in ~15 sec.
I also tend to buy write-centric SSDs where endurance and reliability are more important to me than read speed.
But boot time is a non issue as I tend to turn PC on and only turn it off at the end of the day.
https://linustechtips.com/topic/438117-need-help-choosing-a-cpu/#findComment-5881439
