Cooling plans
Go to solution Solved by dragonelf37,
Thanks for the replies :)
@Aruxxhttps://www.youtube.com/watch?v=VUbpb23yTK8
@FatPenguin: I would guess an all pull situation would be better.
@Toxicable: i know that but if there is enoth pressure it should be able to get it out of the case.
Its either this or mount it in the top.
Would there be a big difference in performance?
Heya pps,
My old AIO just broke down and i was thinking on getting a H110GTX from corsair.
I also just purchased a Corsair 750D case.
So in my hype i made a cooling plan just for the heck of it.
i5ako3.png  The Orange arrows is the planned fan direction.
So will this help the cooling performance by much?
I was also looking into the DH-15 from noctua.
But not sure what the performance difference will be when used at its full potential
My actual build:
PSU: RM1000
CPU: i5 4690k
GPU: XFX 290x
MOBO: GB-D3H Z97
RAM: 16GB Mish mash of AData and kingston sticks ( replaced at next local sale )
Case: Corsair 750D
SSD: Samsung 240 Evo 250GB
HDD: 2x Barracude 1TB
https://linustechtips.com/topic/437691-cooling-plans/
It probably will, I saw a video a while back of this dude putting a TON of fans on an AIO and it having some effect, but think about it in the long run.  You're gonna have to clean dust out of that, it's going to be noisier, and is it really worth it all?
Talking about all the exhaust fans out front.  You could probably get away with just a pull setup imo
"You should look up common sense and add it to your vocabulary." - dougdangger 2015
https://linustechtips.com/topic/437691-cooling-plans/#findComment-5867394
that fan next to the drive bay won't be able to do anything because its covered
also nice diagram and welcome to the forums :D
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/437691-cooling-plans/#findComment-5867397
https://linustechtips.com/topic/437691-cooling-plans/#findComment-5869416
