CSS/HTML - Help with div positioning, follow up question.
The link of what I want it to look like is provided in the question. And what I mean about the mess part is that the elements within the grey box divs are not where they should be and it's probably not coded correctly in the proper way. Could you show me what you mean by table layout I have no idea what that is. A fiddle would be very useful.
how about this?
i don't know what you mean by "the boxes aren't where they should be", now that i fixed the sizes and alignments it looks fine to me, i can't see the teamspeak logo because it's lacking the image but it should be fine if you use a square image (maybe 45x45 already).
yes it's not coded the right way at all, as i said it would be much preferred to use floats, but the result in the link above is achieved by just editing 3 or 4 lines of css, so that's quick for sure
edit: added random image to see if it fits
