I am looking for some led lighting strips with the led spacing to be very small and for then to run off 5v or 12v without modification.
https://linustechtips.com/topic/43738-led-lighting/
Phobya makes stuff like that i think
http://www.phobya.com/eng/phobya.html
Yea ill have to measire to see what length ill need. Where would I find their stuff in the US?
In another not their website sucks! What are they sill in the age where everything is run by flash?
https://linustechtips.com/topic/43738-led-lighting/#findComment-572256
Ikea led strip :)  http://www.ikea.com/us/en/catalog/products/50192365/
Works awsome and color adjustable
  CPU:   Intel I5 3570K @ 4,6 GHZ   -- MOBO: Asrock Z77-Extreme4 -- GPU: EVGA GTX 770 2GB -- PSU:Corsair TX750M -- R AM: 16 GB 1333 MHz -- HDD: 2x 2TB -- 1x 120 GB HyperX SSD -- AUDIO: Creative Audigy 2 -- CASE: Fractal Design R4
-- Actually Like Windows 8 --
https://linustechtips.com/topic/43738-led-lighting/#findComment-572260
I have if you want pics tell me !
https://linustechtips.com/topic/43738-led-lighting/#findComment-572264
Im looking for just white a and something that can be run of DC. Something thats meant to be inside of a PC would help too.
https://linustechtips.com/topic/43738-led-lighting/#findComment-572275
This can it runs of 12v
https://linustechtips.com/topic/43738-led-lighting/#findComment-572280
So your saying the
thick white cable coming from the central box is DC? I really find that hard to believe unless their a AC Adapter on the end of that cable. Either way its not what im looking for.
https://linustechtips.com/topic/43738-led-lighting/#findComment-572303
the ac adapter is on the end I have the thing hooked up to my PSU
https://linustechtips.com/topic/43738-led-lighting/#findComment-572320
Definitely get the ones by Phobya, they're brilliant. :)
know of any place in the US that sells them as their a UK based company.
https://linustechtips.com/topic/43738-led-lighting/#findComment-572577
I'm pretty sure FrozenCPU sells them. :)
Thanks I was looking there but they have so many pages of led strips I thought id see what everyone here suggested  first.
https://linustechtips.com/topic/43738-led-lighting/#findComment-572645
Yeah I found them on there, their site is a mess.
if you know exactly what you need search works but if you dont your on your own going through paged of products.
https://linustechtips.com/topic/43738-led-lighting/#findComment-572681
