How to check whats eating up my internett speed?
Demonhax
So im playing World of warcraft, and im getting a bit of delay. My ping in game is like from 100-300ms.
But on a speedtest its like this: https://gyazo.com/2fe4a7aadcd31f3cb3c966840e5e27c8
I know its different with the servers for wow and my network and so on. but should it jump that high?
Is there any way i can look what using internett and maybe shut that down?
it really depends on how far away the server you play on is and how 'good' of a connection you have between you and it.
Intel I9-9900k (5Ghz) Asus ROG Maximus XI Formula | Corsair Vengeance 16GB DDR4-4133mhz | ASUS ROG Strix 2080Ti | EVGA Supernova G2 1050w 80+Gold | Samsung 950 Pro M.2 (512GB) + (1TB) | Full EK custom water loop |IN-WIN S-Frame (No. 263/500)
Are you using multiple devices on the network?
Main PC: i5 4590 @ 3.5 GHz ♦ RX 480 Armor OC ♦ 16 GB DDR3 ♦ GA-Z97-HD3 ♦ 120 GB 840 EVO ♦ 120 GB Intel 520 ♦ W10 Home
Scrapyard PC: Xeon X5460 @ 3.8 GHz ♦ HD 7870 ♦ 8 GB DDR2 ♦ GA-P35-DS3L ♦ 80 GB Intel 320 ♦ 160 GB WD Caviar SE ♦ W10 Home
Where is the server for whatever WoW games are you playing?
Tried googleing it, but didn't get a answer very easy, so really dont know
Im not sure, maybe a laptop or something, but not that many devices tho.
I mean your internet speed isn't really great or anything, it just may just be connection issues between you and the server like distance. A closer server should result in lower ping.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
yeah, i know it isn't great. but it should be good enough for playing wow. i think :P
Fuck.
Try playing a TF2 or any Valve game's server that is local, or at least closest to you. Then see how the ping is.
So i found out that all the servers are in Paris :P
http://imgur.com/g6aM7tB
I've always had pretty fast internet however when i was going to Brown University sometimes the internet was closer to the speed you posted and it made it very difficult to game, or stream media.
Yeah, at home i have 75/75, but here where i work its a like this :P
