I'm having problems with GTA V since I got Windows 10. IIt's loading longer than on Windows 7 but the most annoying thing is when driving fast buildings are spawning in front of me and the road disappears. It is taking few seconds to load textures like that even when I stop driving. I'm just wondering does anyone have this problem and if yes how did you fix it?
CPU: AMD Phenom II X4 B50 3.2 GHz // GPU: VTX Radeon HD 6670 1GB DDR3 // MB: Asus M4A88T-M // RAM: 2×2GB DDR3 // PSU: MS PRO 550W ATX P4 // Monitor: Samsung 1280×1024 resolution // Windows 10 64 bit // Mobile: LG G3 32 GB
https://linustechtips.com/topic/436913-gta-v-problem-with-performance/
GPU cant render textures fast enough, Simple as that, try lowering some of the settings
It worked perfect on win 10 on even better settings than now. And I have the latest drivers. Could this be win 10 problem?
I've started having issues of the FPS dropping from 90ish to 7. Yep. 7, haha.
Only since Installing W10, but oddly just reducing the draw distance by one notch stopped the issue happening. On 7 I used to get Memory leak on it, but it seems to have stopped on W10.
Try reducing your distance draw scale to free up some VRAM and see if that helps the issue a little?
CPU: i7 7700k. MOBO: MSI Z270 Gaming Pro Carbon. RAM: 32Gb DDR4 Team Group Dark Pro 3k . GPU: EVGA GTX 1080 FTWx2. Storage: 64GB SSD, 250GB SSD,480GB SSD, 1.5TB HDD. PSU: EVGA Supanova 750W G2. Case: NZXT H440 Matte Black. Screens: Acer Predator X34 @ 100Hz & AOC 24" G2460F 144hz. KB: Logi G810 Orion Sprectrum. Mouse: Corsair Scimitar RGB Audio: Edifier S550's & ASTRO A50's. Console Peasant?: PS4 & XBone.
