Building a PC, need help.
Go to solution Solved by sms1202,
@ 850 GBP
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£172.99 @ Aria PC)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  (£49.99 @ Amazon UK)
Motherboard: Asus Z97 PRO GAMER ATX LGA1150 Motherboard  (£99.99 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  (£246.98 @ Novatech)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  (£42.32 @ CCL Computers)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£86.49 @ Amazon UK)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£9.36 @ CCL Computers)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit)  (£67.95 @ Ebuyer)
Total: £853.13
Generated by PCPartPicker 2015-08-24 11:24 BST+0100
First time using this forum d;
Anyways, I was on Toms Hardware looking around, asking for the best possible PC for around £800, and this guy said everything is good apart from your power supply.
This build : http://uk.pcpartpicker.com/p/gXLxMp
Then, I ask about the cooling on another post I made, and then all of a sudden, this guy comes out with "Your PC is made for overclocking, and your GPU price is silly", and then makes me a PC roughly the same price, with a better GPU and air cooling instead. That build : http://uk.pcpartpicker.com/p/Np3Vzy
Now I am just stuck. I don't really know which one to go for.
Please help
P.S Sorry for going a bit off topic
https://linustechtips.com/topic/436517-building-a-pc-need-help/
id go for the second build. The main changes are 960>970 (more powerful graphics card) and changing the I5 from a 'K'  (unlocked multiplyer and allows for overclocking) to a non 'k' version of the same processor. I guess as this is you first pc you wont be overclocking it at all so yeah go for the second build its the best of the two IMO.
Quack 🦆
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851486
Please help
I recommend this:
The R9 390 is even better than the GTX 970.
CPU Cooler: Thermalright TRUE Spirit 120M(BW) Rev.A 46.2 CFM CPU Cooler  (£35.99 @ Amazon UK)
Motherboard: ASRock Fatal1ty Z97X Killer ATX LGA1150 Motherboard  (£99.56 @ Scan.co.uk)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-2133 Memory  (£45.90 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£38.98 @ CCL Computers)
Video Card: MSI Radeon R9 390 8GB Video Card  (£264.99 @ Amazon UK)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£79.99 @ Scan.co.uk)
Total: £858.03
Generated by PCPartPicker 2015-08-24 11:21 BST+0100
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851525
Go for the second build or the build from above. Except NEX series PSU. Get G2 series or GS series instead.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851534
@ 850 GBP
Total: £853.13
MacBook Pro 13" Mid 2012 w/Core i5 3210M and glorious HD 4000 Graphics
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851540
PCPartPicker part list: http://uk.pcpartpicker.com/p/36h6zy
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£24.95 @ Aria PC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  (£60.97 @ Amazon UK)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  (£38.08 @ Dabs)
Storage: Sandisk Solid State Drive 128GB 2.5" Solid State Drive  (£40.25 @ CCL Computers)
Case: Corsair SPEC-02 ATX Mid Tower Case  (£56.99 @ Amazon UK)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£37.99 @ Scan.co.uk)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£75.24 @ CCL Computers)
Total: £811.43
I'd choose Windows 8.1 key then install it through USB and upgrade to 10 with the free upgrade which will save some money on the optical drive. the R9 390 will give some a little more performance than the 970. I've also went back the the i5 4690k with a cheaper Cooler Master Hyper 212 EVO cooler which is a very good cooler for it's price. And for the PSU I've went for a EVGA 80+ Bronze Power Supply which is good enough for your build.
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851557
Please help
second one should have higher fps but you will not be able to sli
would still  go for second one
hakuna matata
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851583
Well, this forum is good, I'll tell you that for sure! :D
But now, I don't know what to choose from! xD
There are so many options here. I might look into getting the R9 390 8GB, that's for sure.
I like Morgan MLGman's build, and Altecice makes me want the second option.
THERE'S TOO MUCH TOO CHOOSE!
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851588
Please help
@ 850 GBP
Total: £853.13
would go for this one though
hakuna matata
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851591
welcome to pc master race my friend ;)
hakuna matata
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851594
@ 850 GBP
Total: £853.13
That does seem nice too, you guys are replying to fast for me to even respond :D
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851599
That one sucks to be honest spend altleast 50GBP more it gives you a r9 390 and you can get rid of 3.5 GB GTX 970
That is the best bet you got
900 GBP is the premium budget
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851624
So, if I got all the parts you picked and just upgraded to an R9 390, would that be alright?
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851638
Also is there a big difference between the R9 390 and the R9 390X?
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851705
No the difference is not worth the extra $100
Get the R9 390 NITRO or the WINDFORCE or STRIX ! They will be on par with a reference 390X
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851776
http://www.scan.co.uk/products/8gb-sapphire-radeon-r9-390-nitro-oc-28nm-pcie-30-(x16)-6000mhz-gddr5-1010mhz-gpu-2560-streams-dp-hdm
This good?
Sorry for asking so much, I just want to be sure (:
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851810
That's Great ! You don't need to apologize for asking doubts!
You apologize to people for being annoying !
https://linustechtips.com/topic/436517-building-a-pc-need-help/#findComment-5851822
