Go to the SteelSeries Engine, then to Settings and make sure Polling Rate is at 1000Hz.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570301
Updating the firmware might help aswell.
Perhaps you got some cat hair in your sensor? [Happens to me all the time]
Yes, firmware might be the problem.  I looked on the SteelSeries website a while ago and it said there was a firmware update for the mouse but the software didn't tell me there was.
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570330
Ive done it (allready had it) but there is still allot of input lagg....
What monitor do you have?
Have you tried unplugging it and plugging it back in again? ;)  If it's in a USB 3.0 port, try a 2.0.
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570355
Using a TV :/
That might be why :P  What TV is it?  I can try and pull up some specs.
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570371
Install the firmware from this link: http://steelseries.com/support/downloads just click on the Diablo III mouse and select the firmware update, then install the drivers for the mouse from the same page.
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570388
That was fast, did the firmware successfully complete?
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570435
Yeah, even tried resetting the pc to a point that it worked and downloaded the firmware again.... still nothing
When I updated the firmware for mine it took about 15 minutes.  Try uninstall all drivers for the mouse and then updating the firmware so there's nothing interrupting it and then when the firmware has successfully updated, install the SteelSeries driver again.  You might need to use the SteelSeries Firmware Repair Tool if the firmware doesn't work properly.
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570449
Didnt work...
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570527
What kind of surface are you using the mouse on? Rough, smooth, mousepad? Clean out the sensor, perhaps?
Interested in Linux, SteamOS and Open-source applications? Go here
Gaming Rig - CPU: i5 3570k @ Stock | GPU: EVGA Geforce 560Ti 448 Core Classified Ultra | RAM: Mushkin Enhanced Blackline 8GB DDR3 1600 | SSD: Crucial M4 128GB | HDD: 3TB Seagate Barracuda, 1TB WD Caviar Black, 1TB Seagate Barracuda | Case: Antec Lanboy Air | KB: Corsair Vengeance K70 Cherry MX Blue | Mouse: Corsair Vengeance M95 | Headset: Steelseries Siberia V2
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-570796
Did you change any settings on your TV?
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/43628-mouse-input-delay/#findComment-573951
