premium headphones for use with youtube?
Thanks for that Could you articulate how much "performance" i may be getting out of the AKG 701s when using youtube? So say flac files or other lossless formats would be talking 100% advantage of the headphones' audio, how much, just roughly so that i have somewhat of an idea, would youtube be using? Of course this has no real bearing on reality, it is just to articulate it in a rough way so that i can comprehend youtube's audio quality slightly better if you know what i mean. Just a rough estimation. Thanks
That's something you can try with your current audio equipment, just download a flac file and compare it with 320kbps/256kbps/192kbps files and so on and see what you can detect. Personally the difference is minimal, and I am using a pair of Th-900 plugged into hp-a8 dac/amp so it's not like my gears aren't capable enough to produce the details. I do primarily use flac or dsd since space is cheap. Now I don't know why you're limited to youtube and spotify free, but just know that you're not missing out on much as people like to claim.
