Hello all! I'm in look of a laptop to use when at school and away from home, I plan on using the laptop for light gaming, and mainly school work and some programming.
I would like the laptop to cost less than $350 or so (Used is perfectly fine as long as the condition is good and the seller is trustworthy), I would also like it to be between 14" and 16", and have at least a 1366x768 screen.
I'd prefer it to be all or mostly black or dark grey.
I'd like to be able to run Skyrim, Minecraft, Diablo III, Elder Scrolls Online, and some other less demanding games on it on at least minimum settings with 30+ FPS at whatever resolution the laptop's screen happens to be.
Max price is $350 USD!
I saw an Asus K53TA on ebay for pretty cheap, same as my old laptop, tempted to get it though the one thing I really didn't like about it was the build quality... (basically all plastic construction...)
I also found an Asus X551CA on ebay for the same amount and it seems like it could be a pretty decent option, not insanely powerful or anything, but good enough to get the job done, and it looks pretty good too.
A slightly more expensive one that I'm also looking at is this: http://www.amazon.com/Lenovo-G50-80E30181US-15-6-Inch-DVD-SuperMulti/dp/B00VIPM9JQ/ref=cm_cr_pr_product_top?ie=UTF8 I'm just not sure on build quality and such with it, it looks like it's brushed aluminum, though for $332 I highly doubt it's actually aluminum, probably just plastic.
https://linustechtips.com/topic/436193-help-finding-laptop/
Get a Chromebook for school and keep the gaming for home.. they can come at around 300$ to 200$
I'd prefer to be able to do shit on the laptop instead of just use chrome :3
Get the Lenovo, its most likely the best for the money.
I'm considering it... don't have quite enough in my bank account to pay for it though :( (Other two are both around $220)
https://linustechtips.com/topic/436193-help-finding-laptop/#findComment-5846800
If your using it for light gaming, its essentially the best you get. If you need to up the speed you can get a SSD
https://linustechtips.com/topic/436193-help-finding-laptop/#findComment-5846811
You're not going to play games like those on integrated graphics at decent settings. save 600 bucks and a laptop with discrete graphics
I used to own an asus k53ta, I got it for like $300 used, I could run skyrim on pretty decent settings no problem with it.
Yeah, though the k53ta seems to be the best in benchmarks :/
https://linustechtips.com/topic/436193-help-finding-laptop/#findComment-5846877
Really? Integrated graphics is stronger than I thought. I ran tf2 on a surface pro and got 45fps on 1080p with high details. I guess i've only seen skyrim with mods
It's not just integrated graphics... it's got a dedicated GPU in it as well... (uses em in crossfire)
https://linustechtips.com/topic/436193-help-finding-laptop/#findComment-5846938
Guess its down to the K53TA and the lenovo...
I just barely have the money to get the lenovo (Though I'd have basically no money left after that), or I could get the K53TA which is more powerful for like $60 less, but I also get worse build quality..
https://linustechtips.com/topic/436193-help-finding-laptop/#findComment-5847317
