Fan adapter
Go to solution Solved by Joshndroid,
Can someone link me a fan adapter than runs the fan at 1/2 speed 3 pin
There's one with a variety of speed from 12V, 7V all the way down to 5V if you want it fixed speed:
http://www.amazon.com/Zalman-ZM-MC1-Multi-connector-Add-Fan/dp/B000FAKUE6/ref=sr_1_1?ie=UTF8&qid=1440292552&sr=8-1&
https://linustechtips.com/topic/435682-fan-adapter/#findComment-5839714
