what CPU should I use with that card? I'm upgrading my lil bros build and I got the 760 used for good price ($125) so I have enough for a mobo/CPU ($180)
I can't go with intel, I don't think the budget allows. and I'm affraid AMD's Athlon 860k bottlenecks the card.
what do you guys recommend?/are using?
the system has 8GBs of ram and a 600W evga psu (bronze) his current mobo is FM2, but he doesn't have usb 3.0 headers in this board. so I'm just going to buy him a new one. but I haven't chosen a board cuz I haven't chosen a cpu :P
"When you're in high school you should be doing things, about which you could never tell your parents!"
https://linustechtips.com/topic/435309-cpu-for-gtx-760-sc/
You can always get an i3 and inexpensive mobo for under 180 USD. On AMD I would personally go for the FX-6300.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
https://linustechtips.com/topic/435309-cpu-for-gtx-760-sc/#findComment-5834399
i3 is definitely in your budget and performs better than fx8 in games.
CPU-delided i5-4670k@4.6Ghz 1.42v R.I.P (2013-2015) MOBO-Asus Maximus VI Gene GPU-Gigabyte GTX 970 G1 Gaming@1582Mhz core/3744Mhz memory COOLING-Corsair H60 RAM-1x8Gb Crucial ballistix tactical tracer@2133Mhz 11-12-12-26  DRIVES-Kingston V300 60Gb, OCZ trion 100 120Gb, WD Red 1Tb
2nd  fastest i5 4670k in GPUPI for CPU - 100M
https://linustechtips.com/topic/435309-cpu-for-gtx-760-sc/#findComment-5835276
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard  ($79.99 @ Newegg)
Total: $191.98
Generated by PCPartPicker 2015-08-22 11:42 EDT-0400
Just a little over but I'm sure you can save like $10
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
https://linustechtips.com/topic/435309-cpu-for-gtx-760-sc/#findComment-5835321
