Add my old cases fan?
Solved by Senzelian,
Possible fan configurations for the Corsair 230T:
- Front: 2x 120mm
- Top: 2x 120mm or 2x 140mm
- Back: 1x 120mm
- Bottom: 1x 120mm or 1x 140mm
Push or pull are terms that are used for radiators. So you either push or pull the air through a radiator.
What you probably meant was if you want to use the fan as an intake or outtake.
I wouldn't use that fan at all, because it's probably loud and doesn't even move a lot of air.
i dont think you can fit a 90 mm fan onto a 120 mm fan socket
you would probably have to drill some new holes, although look if it supports 90mm, a miracle might happen
You cannot drill holes in an already existing mesh. But it is possible to use the mesh as mounting wholes.
No Standard dimension
92mm is a standard. It is used still fairly often in smaller cases. I think the very popular Parvuum cases still use them.
