When I use it very slowly it works fine but when i make fast movement the mouse just spazes out and goes all over the place
(cant upload video b/c idk a uploader that takes uncompressed files)
USB 3.0 and 2.0 does not effect it at all
is this a tracking issue? driver issue???
this mouse is pretty damn old so idk if there are still drivers for it
https://linustechtips.com/topic/433785-weird-mouse-issue/
check where the sensor is for fur. That happens to me cause of my dogs and cats. Then get something small like a tooth pick and clean it out.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/433785-weird-mouse-issue/#findComment-5813684
nope
I think it might be that you're going past the maximum tracking speed of the sensor. I have a Kensington trackball, where if I spin the ball too fast, it goes all over the place because the optical sensor can't handle the speeds involved.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/433785-weird-mouse-issue/#findComment-5814762
Your mousepad cost more... You could try using a usb-to-ps/2 adapter if you have one laying around.
i have another mouse that uses that connection but it dosent work. i dont even know any drivers for it
https://linustechtips.com/topic/433785-weird-mouse-issue/#findComment-5836052
