Hey everyone quick question. First time building and I have a static wrist strap I'm just wondering what would be a good location to build it. I have carpet except for 2 places in the house like my kitchen is all tiles and I have a room with hardwood floors would they be good? Also for using the power supply as the ground and connecting the wrist strap to it should it be plugged in and on the off spot or would it being unplugged be fine?
https://linustechtips.com/topic/433575-building-pc-need-advice-on-static/
Building on tile will probably be your best bet, and just clip your anti-static wrist strap to your case.
Have the PSU plugged in, but the PSU switch and socket turned off. You may wish to use the anti static strap on your ankle, instead of your wrist (as this can give more freedom). Building on a hardwood floor may be a bad idea, because you could possibly scrape the side of your case and/or the floor varnish/finish. If you build there you may wish to put something under your case to protect it and the floor (e.g. the plastic wrapping the case came in). As long as you're protected from static building on the carpet should be OK, but if it's got a deep enough pile you may end up searching for dropped screws/fittings for a while ;)
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
|Intel Core i5-4670K| |Gigabyte Z97P-D3| |Seagate 1TB SSHD| |Fractal Design Define S| |Corsair CS650M| |Asus PB278Q| |Cooler Master CM Storm Devastator Bundle|
i built my own anti static wrist strap and clipped it onto the metal box where the plug ist located behind the socket cover
the metal box show here    http://www.hammerzone.com/archives/elect/repairs/outlet/replace.htm its the metal box that the outlet gets screwed into
edit: yay i fixed the broken link
edit 2: plz be carefull if you use this method, i dont want to be responsible for getting someone electrocuted :/
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
