Hello,
I was just wondering if I needed any thermal paste for my pc (http://pcpartpicker.com/p/ZwLjxr) which I will be receiving in a week or two.
I didn't buy any thermal paste, so I hope I don't need any. Haha
Thanks!
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
https://linustechtips.com/topic/433139-do-i-need-a-thermal-paste/
The cooler should come with it, but I'd buy some thermal grizzly, artic silver 5, or Noctua thermal paste...
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
You never know . . .
Its good to be prepared . . . always be prepared  :P
 CHRISTIAN MEMBER
A thermal paste Is an important thing, without it
YOU'LE DIE
Or your cpu might :P
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
Okay guys, thanks for all the answers! I think I'm gonna go for the Arctic Silver 5 (just in case), that should be ok? I think the cooler comes with though, don't wanna take any risks either way!
Everyday build:
Weekend build:
Yes, that's good.
Okay, I'll buy that one then.
Everyday build:
Weekend build:
I hope you're asking for what brand of thermal paste.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
Hello,
Thanks!
If you're using the stock cooler that comes with the cpu, then yes, it will have pre-applied thermal paste. If you're buying an after market cooler, usually they either come with a small syringe of it or it's pre-applied to the cold plate. However I bought some for my last build just in case and its handy to have around if you need to remove you're cooler for some reason and need to apply fresh thermal paste.
