Here is my review of the Silverstone GD09
I got this case as I needed an ATX HTPC case, and this was the only one that would fit in my cabinet.
Packaging
Nothing to complain about, pretty thick cardboard, thick hard foam, in a plastic back.
8/10​​
Looks
Well its subjective, but its a pretty basic case.
It will go well with any home theater set up.
It has a brushed plastic front, only visible from some angles.
5.25" bay in front. Optical drives match the front,
so its looks like they belong.
2 USB 3.0 and Headphone/Mic on front.
7/10
Build Quality
Well its very solid, especially for 75$ at amazon.
There is a long suport bar going across the top, so the top
should be pretty strong, if one would put a light
monitor on it.
Nice very clicky power and reset button.
The front is plastic, not aluminum, like I would
like, but it was really cheap.
8/10
The Build Experience
Pain free.
Really.
Though the reason for this, is that many
cable management options are not available.
You will want a modular PSU.
I did not have one. Hence my build.
But, it was easy.
Follow the instructions to do it in the right order.
Standoffs are pre installed.
Unfortunately, there is not a tooless mount to be found.
You will need a screwdriver to open the case.
If you dont have a modular PSU,
you will have a big mass of cables.
Finished build looks nice, as there is no window.
8/10
Value
This is where it excels.
$75 is an amazing price for this.
Great build quality and overall product for that price.
10/10
Final
I give it an 9/10.
Great everything, but still a budget offering.
https://linustechtips.com/topic/432861-silverstone-gd09-review/
What are the specs of the system?
Fx-6300
1gb HD 7850
Full specs in profile
https://linustechtips.com/topic/432861-silverstone-gd09-review/#findComment-5803305
Fx-6300
1gb HD 7850
Ah I thought that was ur main and u had others. not like me over here with like 5 systems
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/432861-silverstone-gd09-review/#findComment-5803335
I have 5 others.
They are just all 1999-2002 apple computers
https://linustechtips.com/topic/432861-silverstone-gd09-review/#findComment-5803350
I have 5 others.
Ah.
https://linustechtips.com/topic/432861-silverstone-gd09-review/#findComment-5803367
is this the GD09B?
Yeah
https://linustechtips.com/topic/432861-silverstone-gd09-review/#findComment-5803753
i still have the GD05 it worked very nicely for about 6 years as HTPC. only complaint in these is that they are a pain to open up for modifications after the fact, compared to a side window tower. but, with HTPC, you really build and forget anyway.
Define R5 Black Window || i5 4690K || Scythe Kotetsu || Asus Maximus VII Gene || Kingston Fury 8GB || EVGA GTX 980 Superclocked ACX 2.0 || EVGA G2 750W || SSD/HDD/ODD
https://linustechtips.com/topic/432861-silverstone-gd09-review/#findComment-5803805
