I want a computer that is the "a lower alternative from the best" but is still up to date
for example "Geforce GTX 980Ti" instead of "Geforce GTX Titan X"
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor
CPU Cooling: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: N/A (DDR3 OR HIGHER)
Video Card: N/A (Nvidia Geforce GTX x1)
Storage: Western Digital Caviar Green 2TB 3.5" 5400RPM Internal Hard Drive & Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Power Supply: N/A
Case: Corsair 450D ATX Mid Tower Case
Memory: N/A (2 Sticks Minimum) (8GB Minimum)
x2 5.25 Bays: NZXT APERTURE M 5.25 Bay Multi-Media Mesh Style Card Reader w. Dual USB 3.0 & (All in One Optical Drive)
I going for blue and yellow but it doesn't have to be those colors. (     ) means recommended.
Under $2000 Total not including tax and/or shipping
USA
I causally game, video render/edit and graphic design.
https://linustechtips.com/topic/432734-i-need-help-on-building/
I want a computer that is the "lowest of the best" but is still up to date
for example "core i7 4790k" instead of "core i7 5820k"
Motherboard: N/A (Higher DDR2)
Video Card: N/A (Nvidia Geforce GTX)
Power Supply: N/A
2x 5.25 Bays: NZXT APERTURE M 5.25 Bay Multi-Media Mesh Style Card Reader w. Dual USB 3.0 & (All in One Optical Drive)
I going for blue and yellow but it doesn't have to be those colors. () means recommended.
Must not be too expensive.
would help if you told us your max budget, location and uses.
"must not be too expensive" that doesn't tell us anything about your max price. could be $200 could be $5000
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/432734-i-need-help-on-building/#findComment-5800672
M9 DDR2 is obsolete, do you mean DDR3?
Also use PCPartPicker please.
Oh and what's your budget. Can you afford a 980 Ti/R9 Fury or can you only afford a 980/R9 390X or 970/R9 390/R9 380 and can afford two 500GB SSDs or only one 250GB SSD?
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/432734-i-need-help-on-building/#findComment-5800686
Use PCPartpicker to start. Website has compatibility checkers that'll help.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
https://linustechtips.com/topic/432734-i-need-help-on-building/#findComment-5800715
4790K lowest of the best? thats news to me, i may have to upgrade
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/432734-i-need-help-on-building/#findComment-5800717
I think he thinks that the 5820K is significantly better (it's not in most cases (specifically gaming, games still only benefit from higher single core performance actually if I recall correctly a CPU intensive game like WoW doesn't even benefit from better multi-core)) however multi-threaded a 5820K might make a 4790K weep (at least according to a couple geekbench results and passmark.)
https://linustechtips.com/topic/432734-i-need-help-on-building/#findComment-5800751
