Hello,  I've been getting tired of my laptop which is always crashing and runs games horribly (probably cause the gpu overheats and throttles down) so i asked my parents if i could make myself a desktop they said sure give them a few months to get my parts etc etc and here i am  please consider. i'm only 13 and my parents are paying for all this so i'd like to keep the psu price under 80$ and the case 100$ thanks.
Here's my build
http://pcpartpicker.com/p/Y8vG4D
Also when pcpartpicker says
  • Some Intel B85 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs. is that useless to me? maybe the bios is already updated if i buy the moba from newegg? i don't know . I'd like a good case for the benifits i could get out of it and the psu i don't know much about but thanks .
oh yeah i'm getting windows 8.1 off reddit if i get scammed it's only 15$ instead of 90$ right hehehe.
also i use a w1907 monitor
https://linustechtips.com/topic/432477-help-needed-for-case-power-supply/
Here's my build
Here are my recommendations :)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Total: $153.99
Generated by PCPartPicker 2015-08-18 02:32 EDT-0400
The compatibility issue posted by PCPartPicker should not be a problem, most B85 mobos sold online now are manufactured after the release of Haswell Refresh meaning they will have updated BIOSes to support those processors.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
You just wrote $700-800, this would be better then (removes some compromises I made)
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($176.95 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($67.89 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($43.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.88 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card ($329.98 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case ($40.00 @ NCIX US)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($51.99 @ SuperBiiz)
Total: $760.68
Generated by PCPartPicker 2015-08-18 02:38 EDT-0400
Total: $153.99
Well Would bob's build be better or would this one
http://pcpartpicker.com/p/dQ9Hgs
i need bob's opinion on this too thanks
And Since i dont like micro mobas much should i change it to a atx for 50$ since it's only hit 701$
Total: $760.68
I only gave you the case and PSU because that was what you asked and your PCPartPicker link didn't work.
But I would go with @Bob_Jim 's build, it is better in my opinion.
Echelon Mk 2.11
The reasons why i don't want his build is cause he's using such a expensive gpu which has a shit ton more power than what i need
A few $$ Over but IMO a better build (as swapping out the GPU will be cheaper in the long run)
http://pcpartpicker.com/p/Ytd7jX
You can make that mobo CPU/RAM last for ages. And your monitor is only a 19" screen so a 390 is a bit overkill.. Also add an HDD down the line.
NB: Only buy the K IF YOU PLAN TO OVERCLOCK
CPU: Intel Core i5-4690K 3.5GHz Quad-Core OEM/Tray Processor  ($225.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($25.98 @ OutletPC)
Motherboard: ASRock Z97M Pro4 Micro ATX LGA1150 Motherboard  ($77.98 @ Newegg)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($36.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($79.99 @ Newegg)
Video Card: XFX Radeon R9 380 2GB Double Dissipation Black Edition Video Card  ($179.99 @ Newegg)
Case: Fractal Design Core 1300 MicroATX Mini Tower Case  ($44.99 @ Directron)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply  ($36.99 @ Newegg)
Total: $708.90
Generated by PCPartPicker 2015-08-18 02:59 EDT-0400
Also you could swap the BX100 for an 850 Evo (250gb) which should give you a tad better mileage... Add an HDD later if you cant afford it...
390 is still just about in the sweetspot; though its definately a higher end card  little way into diminishing returns. His is still a very solid build tho. In games you get far more benefit from GPU than CPU.
Ok then use this:
Motherboard: Asus H97I-PLUS Mini ITX LGA1150 Motherboard ($101.99 @ SuperBiiz)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive ($60.98 @ Newegg)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card ($227.55 @ Newegg)
Case: Cooler Master Elite 130 Mini ITX Tower Case ($44.99 @ Micro Center)
Total: $758.32
Generated by PCPartPicker 2015-08-18 02:56 EDT-0400
Slightly less powerful GPU, an SSD for faster load times and boot times, and all in MITX form factor so it can just sit on your desk.
Ok the things u guys dont understand is that i dont need such a powerful gpu ;-; a Sapphire Radeon R9 270X 2GB Dual-X Video Card would be enough because i only want to run trove, planetside 2 ,warframe at full settings with 40 fps+
Then take pretty much any of our builds and drop the video card.. Honestly though see this...
The R9 380 is the lowest most of us would recommend buying new.... If you are gonna spend less buy a used last gen and save some cash... (Given they are all pretty much tweaked rebrands)
i just don't like the ideas of having an micro atx case or itx because the itx on my desk i can knock it off easily if i trip over something which happens all the time i can simply put them on the ground yes but i want decent airflow for all my parts so spending a bit more money on the case ill easily do  an ssd i want one yes but  im patient with things so i can wait for my system boot up and games etc.
I have that case... it isnt exactly small and I leave mine on the ground....
Honestly it sounds like you have made your mind up of what you want...
ok ok ok i understand i'm being a little bit unreasonable but how would be the airflow in that system http://pcpartpicker.com/p/gMxvxr
Does it get hot and since i am a first time builder will it be hard to put things in?
