Hi,  i'm trying to build my first gaming pc, and i chose these parts
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($64.99 @ Mwave)
Motherboard: Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($239.00 @ Amazon)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($312.99 @ NCIX US)
Total: $1352.88
Generated by PCPartPicker 2015-08-17 09:33 EDT-0400
Now i have following questions:
1) is this psu good enough for this build, i do intent to overclock
2) end of this year i'm planing on buying ultra wide monitor, will 970 be alright or should i go with 980 rather instead
https://linustechtips.com/topic/431914-first-build/
I would throw in maybe a bit of a higher wattage psu for those components.
Also you could save a bit of money on the mainboard and some on the HDD, without noticeable differences.
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
https://linustechtips.com/topic/431914-first-build/#findComment-5790690
Looks good overall to me. Perhaps like @Mecami said maybe go for a higher wattage psu like the 650. This will also give some more headroom if you plan to overclock someday.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
https://linustechtips.com/topic/431914-first-build/#findComment-5790750
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard  ($118.99 @ Amazon)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X Video Card  ($434.98 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Total: $1268.14
Generated by PCPartPicker 2015-08-17 10:00 EDT-0400
Cheaper Motherboard
Stronger and Faster Card
You can upgrade RAM in the future when needed
Larger case; room for future upgrade will be there soon
https://linustechtips.com/topic/431914-first-build/#findComment-5790785
CPU Cooler: Noctua NH-U12S 55.0 CFM CPU Cooler  ($64.99 @ Amazon)
Motherboard: Asus Z170 PRO GAMING ATX LGA1151 Motherboard  ($169.99 @ Newegg)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($328.99 @ SuperBiiz)
Total: $1240.79
Generated by PCPartPicker 2015-08-17 10:07 EDT-0400
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/431914-first-build/#findComment-5790805
