Does Low Hard Drive Cache Speed Affect Gaming Performance?
I ask this because everything in my PC is very high end except for the hard drive.
System Specs:
CPU: i7 4790k @ 4.0ghz
GPU: NVIDIA GTX 970 SC ACX 2.0
RAM: 16GB DDR3 @ 1600mhz
OS:  Windows 7 Ultimate
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136178
Cache affects load times.
wouldn't call that build "high-end" though.
Really..? I'm scared to see what you consider high end.. It's definitely strong enough to max anything out right now.
Thanks for your reply though. I do understand it affects loading times, but was just curious to know if it affects anything fps wise, but with these replies it's quite blatant that it doesn't.
Max's it out at 1080p, need to remember at higher resolutions that 970 is going to choke.
I only consider my build middle-high.
5820k and a 980 Classified.
PEWDIEPIE DONT CROSS THAT BRIDGE
