Specifically a H440, I have an i5 4670K(not OC'd yet). I'd like 30C idle and 60C max under load. Maximum $100 CAD.
Of course there's no way to tell for sure the temps, but I'll leave the choosing up to you guys.
kraken x61?
corsair h105?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
He said max $100 CAD...
I have to adjust for the Australia tax, sometimes it isn't perfect.
Anybody that feels like bitching about prices in their region...If they're not brazillian, I really feel for you man, but shake it off pussy.
We cannot find this item...I love how your suggestions work so well...... check your links.
Alright, I made a mistake and I fixed it, ye don't have to be an asshole about it.
yeah...I actually do...
okay, no I don't but it makes me feel better.
My point was that anything less than a 240mm AIO can be bettered with a comparable aircooler.
