Hello everyone so today i tried to play fallout new vegas but it doesn't work. When i try to start it up the menu never comes up! And a message appears and it says: Master missing check your mod load order. So what load order should i have in nexus mod manager for the following mods??? Oh and i don't have any dlc!
Casino Heists by korisanderES
Colt N99 10mm pistol (replacer) by Tosty Fresh
EVE-Essential Visual Enhancments by weijisen
Lucky 38 Suite Reloaded v4 by chocbar98
New vegas enhanced camera by LogicDragon
New vegas stutter remover by skyranger-1
Nevada skies-Weather effects by Yossarian
Nvac-New Vegas anti crash by queued
Official pip-boy readius New vegas edition by AlexScorpion
Perk per level-level cap at 100 by dewguru
Project Nevada Core by PN Team
Project Nevada Cyberware by PN Team
Project Nevada Equipment by PN Team
Project Nevada Rebalance by PN Team
Project Nevada-EVE Support by PN Team
Roleplayer's Alternative start by Gribbleshnibit
The Mod configuration menu by pelinor
Updated PT92 Taurus 9mm handgun by KevinsHope
Weapon retexture project-WRP by millenia
Yukichigai Unofficial Patch-YUP By Yukichigai
https://linustechtips.com/topic/431135-load-order-problem/
Did you make sure that your mods DO NOT require any DLC?  If they do require DLC, then they are likely the cause of your issue.
Besides that, post up a screenshot of your plugin list, not your mods.  There is a tab at the top left of your mod manager that sais plugins, click it, that is the actual order of data files.
Also here is a suggestion:  Remove the "perk per level/level cap 100" mod.  You can achieve this same effect in the Project Nevada menu's.  You can set your perks to be available every level, and you can raise the level cap to your desired level IF you have the extended options PN mod, which is linked in the PN main description page and I highly recommend it.  I don't suggest putting your level cap at 100, there is known issues with it anywhere higher than 90.  Put it at 85.
https://linustechtips.com/topic/431135-load-order-problem/#findComment-5786392
It's ok I fixed it i just didn't have project nevada to load first now everything works!
https://linustechtips.com/topic/431135-load-order-problem/#findComment-5790070
Why?
For one it almost instantly tells you if you have a missing master mod.
My Build:
CPU: i7 4770k GPU: GTX 780 Direct CUII Motherboard: Asus Maximus VI Hero SSD: 840 EVO 250GB HDD: 2xSeagate 2 TB PSU: EVGA Supernova G2 650W
https://linustechtips.com/topic/431135-load-order-problem/#findComment-5790190
