I know nothing about how car audio works.
I just know that my 2006 rav4 I'm getting passed down sounds terrible. What parts would I need to get to make it better?
https://linustechtips.com/topic/430974-car-audio/
https://linustechtips.com/topic/430974-car-audio/#findComment-5778916
I have a spare Ken-wood amp for 2 channel stereo that's from the 90's if you want it
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/430974-car-audio/#findComment-5778930
Is it good?
And then I would also need to find some nice speakers
https://linustechtips.com/topic/430974-car-audio/#findComment-5778962
Is it good?
My dad told me it was lik the best one you could get for money, it was from the KCA line, he got it in Canada, and you know in Canada when people mod their car they do it right.
https://linustechtips.com/topic/430974-car-audio/#findComment-5778978
get a better receiver first with 50w x 4 and It has to have pre outs for front, rear and sub. (theses are for your amps later on) I recommend pioneer. if still don't like the sound then you add a amp. If still not to your liking start changing speakers with better ones.
Don't worry if plan A fails, there are 25 more letters in the alphabet.
https://linustechtips.com/topic/430974-car-audio/#findComment-5778979
get a better receiver first with 50w x 4 and It has to have pre outs for front, rear and sub. (theses are for your amps later on) if still don't like the sound then you add a amp. If still not to your liking start changing speakers with better ones.
And how would I change all these parts?
I'm a car noob.
https://linustechtips.com/topic/430974-car-audio/#findComment-5778985
Depending on the factory stereo you have on the car. See videos on how to remove the panels if need but if its a regular one. you just remove the cover and there's a tool that comes with your new receiver that you can use to pop out the old one. Then carefully remove it since there are wires at the back. Then follow the manual on how to put it on the new one
https://linustechtips.com/topic/430974-car-audio/#findComment-5779015
I'm a car noob.
if your not comfortable messing around with cars electrical systems im sure theres a garage by you with good reviews that could swap them out for you i personally hate working on cars with electrical systems thats one of the reasons im buying that crosley
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
https://linustechtips.com/topic/430974-car-audio/#findComment-5779024
Wouldn't the speakers be most important?
Right now it has ear peicingly bad treble and overall not good
https://linustechtips.com/topic/430974-car-audio/#findComment-5779049
you could do that first. Try to buy something that could handle a amp so that you have room for upgrade later on and buy the correct size. Just google the size that fits your car speaker mounts. On some occasion you can go a little bit bigger which i would do if possible.
What is your plan about the car's audio, do you want to set it up or just have it working like before?
https://linustechtips.com/topic/430974-car-audio/#findComment-5779150
What do you mean
https://linustechtips.com/topic/430974-car-audio/#findComment-5781494
What do you mean
I mean to do you want it to just work with the head unit/receiver and the speakers and the car like just fix it up like new or do you want to add amps and sub woofers? Like have really nice setup. This will be the first thing to consider.
Option 1
If you just want to have have it working then you should start by just replacing the part that have a problem. I suggest buying mid bass speakers from pioneer they are cheap and i like them.
Option 2
If your gonna set it up. You have to plan out the parts that you need to buy. That was my first impression that is why i suggested to get a nice head unit and for the speakers in case you go this route i like jl audio. A bit pricey but nice.
Try to read more on this site:
http://www.crutchfield.com/S-zPuQ6guDK7J/carsystems/Toyota-Rav4-Stereos-and-Speakers.html
https://linustechtips.com/topic/430974-car-audio/#findComment-5785959
Option 1
Option 2
Well I mean it works, just doesn't sound very good..
hold on I got go to dinnner
https://linustechtips.com/topic/430974-car-audio/#findComment-5785974
why don't you try this:
http://www.amazon.com/Pioneer-TSG1345R-5-25-Inch-2-Way-Speakers/dp/B00NF5EQHK/ref=sr_1_4?s=car&ie=UTF8&qid=1439767950&sr=1-4&keywords=5.25+inch+speakers&refinements=p_89%3ASony%7CPioneer
I have a pioneer in one of my car and i'm happy with it.
https://linustechtips.com/topic/430974-car-audio/#findComment-5786083
https://linustechtips.com/topic/430974-car-audio/#findComment-5786108
