i want to have near max performance on 1080p, (on the latest games: Witcher 3, fallout 4, etc)
but the ability in a couple years to upgrade (to 1440p or even 4k).
option1: buy a cheaper gpu now( for 1080p) and buy a newer one later (for 1440 or 4k).
for example a r9 290x or gtx 970
option 2: buy the latest gpu and upgrade to dual gpu with crossfire/SLI when i need more performance
ex. gtx 980, r9 furyx
Taking into account the release of direct X12: amd vs nvidia?
https://linustechtips.com/topic/430972-gpu-dilemma/
a 980 will last a long time
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/430972-gpu-dilemma/#findComment-5778912
Fury (non-X) all the way - right in between 980 and 980Ti
https://linustechtips.com/topic/430972-gpu-dilemma/#findComment-5778925
I would just buy a 390 for 1080p then upgrade later to the latest architecture avaliable
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/430972-gpu-dilemma/#findComment-5778935
