Hello all. I recently got some noctua ppc fans for my case. I installed them and i went in to my bios to change the fan speed. My bios fan control looks like the one shown in this video:
though an issue i have ran into is i cant make the duty cycle any lower than 60% which leaves the fans running at 1500 rpm (which is a bit to audible for my tastes), if i try to go any lower than 60% i get a "invalid input range" message. Anybody know why this might be?
https://linustechtips.com/topic/430345-bios-fan-control/
3pin fans? Try selecting powering mode as DC for them. If they are PWM, select PWM. With some BIOS controls (Seen this on MSI before), you can't go lower than 60% with 3pin fans. Thats 5V. Software allows you to go all the way down to 30%.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5772373
They are 4 pins. There is no area to select between DC or PWM
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5773473
Go to the Asus website, select your motherboard, in the downloads you should be able to download fan xpert 2, which is great at controlling fans attached to the mobo.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5774543
http://www.asus.com/us/Motherboards/Z87A/HelpDesk_Download/
Select your OS and download AI Suite 3, it should have a software fan controller included. You can find it on utilities.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5774568
I downloaded it but there was no fan software in the installer.
Odd...what about BIOS profile? sometimes you can even do fan curves on the BIOS...
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5785440
When i got to install it and it has me chose which parts to install there is no fan software
You install the entire AI suite III it self it has overclocking, USB charge control stuff and all that included. With it comes Fan xpert that allows you to go in and control each fan header.
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5795461
Ok. after i did the "fan tuning" i was able to control it and lower it down to 40% (which according to it translates to 800RPM).
Do you think there is any way to get the bios to be able to have more control?
Im not a fan (lol) of having a bunch of process running using up resources just so i can control my fan's
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5796916
Unfortunately for AI suite it needs to run in the background to have temp control fan curves the BIOS only has a really general set of speeds they allow, I don't think they integrate temperature controllable fan curves in the BIOS on the Z87 boards.
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5796955
I dont really care about curves but just having a lower % option. AI suite allows me to go as low as 800 RPM while bios only allows as low as 1500 RPM.
https://linustechtips.com/topic/430345-bios-fan-control/#findComment-5800692
