Hello World, (see what i did there?)
In advance i don't know if i'm posting this in the right section so if not just tell me I'll delete it.
So, my problem. I'm running fairly old rig :
motherboard: GA-MA74GMT-S2
RAM: 8GB
CPU: AMD Athlon II x4 640 with 4CPUs and ~3.0GHz per core
GPU: AMD Radeon HD 5770 1GB GDDR 5
and i would like to get something a little bit better so i could run witcher 3 on minimum at least.
problem is that as a student i don't really flourish with cash. I can either choose better GPU or CPU in a prize range about $100-$150 (or better 2000 CZK - 4000 CZK).
should i get new CPU or GPU? or new rig entirely?
I'll appreciate any kind of help or advice.
Thank you in advance
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/
I would chuck the GPU first, then new CPU sooner or later.
If youre not looking to get into the used market, then you can probably get a 270X for $150
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/#findComment-5761460
if you're asking new rig or new components, I always say just put together a new rig entirely.
CPU: I7 4790k  CPU Cooler: NH-D15 GPUMSI 970 4gb   Motherboard: z97 Gaming 5 PSU: Corsair hx850   Ram: Corsair Vengeance 8 gb  SSD: Samsung 850 Evo  Case: Air 540
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/#findComment-5761545
New rig, I'd throw the old one out or repurpose it
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/#findComment-5761810
i was affraid that this will be the case. Is it possible to build a good gaming rig (with tower case) and not go over $400?
400$ upgrade is what you want
and yes its doable
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/#findComment-5763728
and yes its doable
i was hoping for more of a tip what to get :) i'm not really good with these. like should i get nvidia, ati. Is it better to go for a worse CPU and better GPU or go for something like i7 and worse GPU.
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/#findComment-5763851
we need full specs on your pc
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/#findComment-5763867
If you're willing to use Linux and not Windows, sure
http://linustechtips.com/main/topic/429718-a-challenge-console-killer-pc-between-350-and-400-usd/#entry5762973
Check the other posts there too, not just mine
https://linustechtips.com/topic/429608-tips-for-rig-upgrade/#findComment-5767510
