I was trying 64-bit version... Wow, huge improve than 32-bit and no more memory hogs. I noticed Firefox 32-bit memory size on processes was very high, almost 1GB all time. But now 64-bit stay low at 300MB or less. Something wrong with 32-bit version, I will checking it later... Did anyone tried that Firefox Nightly 64-bit before?
CPU:AMD Ryzen 5 5600 3.5 GHz Processor | CPU Air Cooler:Thermalright Assassin X 120 Refined SE | Motherboard:MSI B450M GAMING PLUS MATX AM4
Memory:G.Skill Ripjaws V Series 32GB (2x16GB)  DDR4-3200 | GPU:PowerColor Fighter Radeon RX 7600 8 GB Video Card
Storage #1:Silicon Power A55 512GB SSD (OS driver) | Storage #2: Silicon Power A60 1TB M.2-2280 PCIe 3.0 X4 NVMe (Anything else)
Case:Cooler Master MasterBox Q300L | Case Fan: 3x Thermalright TL-C12C (2x intake fans, 1x exhaust fan)
Power Supply:Corsair CXM (2015) 450W Bronze 80 Plus |OS:MS Windows10 (64-bit) | Monitor: ASUS VG275 27” 1080p 75 Hz FreeSync
https://linustechtips.com/topic/429478-firefox-nightly-64-bit/
Do you mean waterfox or Firefox's 64-Bit version? I used Waterfox for quite some time, but didn't get used to all the bugs and little hickups it had basically all the time.
If you use Firefox 64-Bit, is it as buggy as Waterfox?
I once had one of these, now I've got this.
https://linustechtips.com/topic/429478-firefox-nightly-64-bit/#findComment-5759973
I using Mozilla's Firefox "Nightly"  64-Bit version.   I just downloaded it 3 days ago. I notice my "New Tab Wallpaper" extension don't support it yet... I don't notice any buggy yet.
https://linustechtips.com/topic/429478-firefox-nightly-64-bit/#findComment-5760151
I've been using the Developer Edition (one after Nightly) 64bit builds for a while, and haven't seen much of a reduction in memory usage. It has been more stable at higher memory usages though,
Also, moved to Operating Systems and Software
HTTP/2 203
https://linustechtips.com/topic/429478-firefox-nightly-64-bit/#findComment-5760552
