Hi,
I have a Toshiba Canvio Desk 5TB external drive.   Is it possible to open up the case and remove the disk.  I would like to put it in an external drive bay with a Ethernet connection.  Thank you.
David
Theoretically yes it can most times they are either screwed together or clipped so in most situations you can pry the plastic case off but most likely it will be damaged in the process.
I do this at work all the time. You should be able to take the enclosure apart and get the disk out, which should then function any way that a regular hard drive would (i.e plugging it into your computer as a regular internal hard drive, using an external power adapter and a sata to usb cable, etc). Hope this helps.
one would think  :huh:
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
A lot of the time depending on the external inclosure, you will need to break clips to open these. With a bigger one like that you might be able to open it without damage.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
I have to agree. Everytime I have to pull out an external hard drive from an enclosure...the case usually doesn't make it. They aren't really meant to be taken apart.
Thanks for the fast replies.   I'm not worried about destroying the case.  I doubt I'll reuse it again.   I can't seem to find the internal version of this drive so it might not be worth it.  Oh, I was going to put it in a dual drive bay.   Thanks again.
David
David
Most of the internal drives with a regular sata data and power especially the desktop drives but some of the small 2.5" portable ones to save space directly solder on a USB3.0 port to the drive's PCB and any hardware needed.
