Would I need more fans
Kinuubi
So I have a build with the parts all set and a thought occurred to me. Will I need more fans or is the x61 good enough for the cpu? And in general should I get fans with this build http://pcpartpicker.com/p/NdH7jX .
You'll have 4x 120mm case fans and 2x 140mm rad fans, you should be more than fine.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
You don't need any more fans
Lol thanks guys. Just needed to know from other people :-D
I don't think you can add anymore fans. However you can replace them for quieter ones
I just might do that, but only if the noise is annoying to me.
No need for them... cause I'm your biggest FAN !!!!!!!!
Listen, Smile, Agree.
Then do whatever the fuck you were going to do anyway
